90 to a 96?????????????????help
  • 28 Replies
  • 5903 Views
big_kountry21
« on: February 07, 2008, 10:37:30 AM »
will the tranny interchange between a 90 and a 96? help please
Offline Armour
  • 360
Re: 90 to a 96?????????????????help
« Reply #1 on: February 07, 2008, 01:27:23 PM »
man or auto?
big_kountry21
« Reply #2 on: February 07, 2008, 02:23:35 PM »
5 speed manual
Offline Armour
  • 360
« Reply #3 on: February 07, 2008, 05:00:33 PM »
i think they are all the same. I am not sure if they differ from 8V to 16V though!
Offline takai
  • 907
« Reply #4 on: February 07, 2008, 05:26:29 PM »
I would think that they interchange. I believe the bottom end is the same for both the 8V and the 16V and that would be what the belhousing bolts up to.
'Cause, I am to misbehave.
big_kountry21
« Reply #5 on: February 07, 2008, 05:33:37 PM »
i called the chevy dealership and he said differ part numbers.
Offline Armour
  • 360
« Reply #6 on: February 07, 2008, 09:38:54 PM »
Thats prob the difference. 90 had 8V and 96 was  a 16V i am almost certain. Can anyone else back this up? I am not 100%.
big_kountry21
« Reply #7 on: February 07, 2008, 09:40:36 PM »
so does that mean they will match up?
Offline Armour
  • 360
« Reply #8 on: February 07, 2008, 09:42:55 PM »
I thought they were the same. But don't quote me. If I were you i would hold tight for a bit and see what some more people have to say on this post.
big_kountry21
« Reply #9 on: February 07, 2008, 09:45:06 PM »
kk....... i hate to buy that tracker and the shit not bolt up...... its only $300 though
« Reply #10 on: February 08, 2008, 05:00:39 PM »
16V and 8V manual trannies will interchange.  The 16V engines have bracing brackets that go back to tranny.....but an 8V tranny will work (just don't use the bracing brackets).
The 16V tranny has a .795 5th gear ratio.
The 8V tranny has a .86 5th gear ratio.
All other gear ratios are the same.
The 90 tranny may have 2 sensors on the tranny (the 5th gear sensor and the reverse sensor).....the 96 tranny will probably just have the reverse sensor.  Just don't worry about hooking up the 5th gear sensor on the 90 tranny....it will still work fine without it hooked up.
big_kountry21
« Reply #11 on: February 08, 2008, 05:07:14 PM »
you are the freakin man. i needed to know that. i found a 90 trak for 300 bucks and the tranny for mine is 450 at the cheapest...... thanks a million.
« Reply #12 on: February 08, 2008, 05:44:05 PM »
One other thing to note.....the tcase on the 90 tranny will have a 26 spline (IIRC) output shaft......the tcase on your 96 will have a 16 spline (IIRC) output shaft.  The tcases will interchange, so you won't have a problem there, or you can swap the slip yoke from the 90s driveshaft over to the 96s driveshaft.
big_kountry21
« Reply #13 on: February 08, 2008, 06:06:37 PM »
which is better 16 or 26?
« Reply #14 on: February 08, 2008, 06:15:05 PM »
IMO, there is no difference.  I don't know why they changed the spline count.
