guage cluster
  • 1861 Views
big_kountry21
guage cluster
« on: February 08, 2008, 10:36:40 AM »
how do you get it out..... 96 2 dr 4x4  trak.
Offline Armour
  • 360
Re: guage cluster
« Reply #1 on: February 08, 2008, 10:44:28 AM »
I have never done one but it can't be that hard. Remove the bezel around the cluster. It should be held in with screws. Remove the screws holding the cluster in. I am not sure if they have a speedo cablr or if it is electric. If a cable there should be a clip that you push. Grab the cable going into the back of the speedo. Push the retainer and pull cable off. If electric disconnect plugs. Like I said I have never done a tracker before. Just tell my past experiences with other vehicles.
big_kountry21
Re: guage cluster
« Reply #2 on: February 08, 2008, 10:46:49 AM »
thaqts what i'm huntin is a loose spedo cable.... little bastard got me a ticket yesterday. lol :P
Re: guage cluster
« Reply #3 on: February 09, 2008, 06:48:54 AM »
Thats pretty much it. I found that the cable isn't easy to get to. If you disconnect it from the trans first then you can pull it through with the clocks and then you can get your hands to it.
big_kountry21
Re: guage cluster
« Reply #4 on: February 09, 2008, 11:17:55 AM »
i figured it out.... its the spedo it self. so i gotta geet one
