Vacuum routing
  • 2419 Views
Offline biker
  • 730
  • It's a sickness I tell ya
Vacuum routing
« on: June 12, 2005, 06:08:58 PM »
I just swapped an auto into my 91 Tracker in place of a tired 5 speed. I'm unable to find a place to hookup the hose off the tranny modulator on the intake. I Tee'd it into the line for the canister where it connects just under the throttle body as a temp fix.  Does anyone have the FSM that could lookup where it is supposed to go or if someone has a factory auto truck that wouldn't mind taking a peek for me.
Thanks in advance for any help you can offer :)
« Last Edit: June 12, 2005, 06:09:43 PM by biker »
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Re: Vacuum routing
« Reply #1 on: June 13, 2005, 03:20:30 AM »
The stock location is a port at the back of
the intake, it's on the #4 intake runner,
and not far from the throttle opener cam.
The Trans had a small can shaped fitting,
about 3/4-7/8 of an inch round, with a snout
sticking out of the end, I think this is a check
valve, tho I don't know what for, perhaps a filter ?
Where you have the vacuume hose routed
now should be fine, unless you want it to look
bone stock
Offline biker
  • 730
Re: Vacuum routing
« Reply #2 on: June 13, 2005, 12:26:12 PM »
Thanks Wild, looks are not a big deal just after function. It seems to shift fine so I'll leave it as is for now.
99 Vitara 2wd
10 Gr Vitara
Offline 90Stomper
  • 427
Re: Vacuum routing
« Reply #3 on: June 14, 2005, 03:44:45 PM »
got pics or a write up of this swap?
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
