1.6L 16V header
  • 2745 Views
Offline fallguy
  • 127
1.6L 16V header
« on: February 12, 2008, 01:48:51 PM »
who makes a good 1.6L16V header the only one out there that i have seen is calmini's are there anny others ?
thanks
MaD.72
Re: 1.6L 16V header
« Reply #1 on: February 12, 2008, 02:05:33 PM »
Re: 1.6L 16V header
« Reply #2 on: February 12, 2008, 03:48:02 PM »
I've got the 16V Calmini stainless header.  Direct fit and a real nice item.  Price is decent as well.
Offline fallguy
  • 127
Re: 1.6L 16V header
« Reply #3 on: February 12, 2008, 04:44:50 PM »
i didnt think calminis were stainless i thought they were only ceramic coated?
Re: 1.6L 16V header
« Reply #4 on: February 12, 2008, 05:50:11 PM »
I believe Hawk Suzuki sells one as well.
Offline RACER X
  • 383
  • zuki or die!
Re: 1.6L 16V header
« Reply #5 on: February 12, 2008, 08:11:21 PM »
dOUG tHORLEY SELLS THE BEST IVE DONE SOME RESEARCH ABOUT 6 MONTHS AGO AND DT BEAT THEM ALL
98 kick
Offline ROSS
  • 1412
Re: 1.6L 16V header
« Reply #6 on: February 12, 2008, 08:33:06 PM »
The 8V is stainless 16V is ceramic from calmini
phloop
Re: 1.6L 16V header
« Reply #7 on: February 12, 2008, 09:12:47 PM »
OK, who sells a 16v header other than c-m or rr. Does Doug Thorley really make one? I will be looking for one this summer and will not deal with either of the two dealers mentioned.
Past dealings with those two cheezy out-fits has left a bad taste. :P >:(
Offline lostsamurai
  • 433
  • LOSTSAMURAI
Re: 1.6L 16V header
« Reply #8 on: February 12, 2008, 10:47:29 PM »
Low range off road out of provo utah has the doug thurley and the calmini in stock, I compared them side by side and while I like how the dt goes all the way down to your catalytic converter, the calmini has a way better look, tig welded ported to match the gasket no restrictions, just all around nicer in my opinion im happy with the calmini.
