Suzuki Samurai Weber Carburetor Conversion Kit E-Choke
  • 12 Replies
  • 11583 Views
SkipTLoo
« on: February 15, 2008, 10:18:42 PM »
This is the carb I would like to buy!!! But would I need to buy an intake??  Or does it bolt on??? What will i need?  I have a 1986 1.3
sanjuansheriff
Re: Suzuki Samurai Weber Carburetor Conversion Kit E-Choke
« Reply #1 on: February 16, 2008, 12:49:57 AM »
Skip....
I have a 86 Samurai that I put a Weber on with the E-choke a few months ago. I bought it for under 3 bills off of eBay with everything needed to install, I was even able to use the stock air cleaner. I really like it.
Hope this helps,
Dennis
SkipTLoo
« Reply #2 on: February 16, 2008, 08:29:22 AM »
it came with a manifold???? or does it bolt on??
« Reply #3 on: February 16, 2008, 10:54:12 AM »
The Samurai Weber kits come with an adapter plate that goes onto your existing manifold.  Other then tuning it is pretty much a bolt on affair.
If your looking at new carb alternatives, there are also the side draft conversions available as well.
gatorbus
« Reply #4 on: February 16, 2008, 12:35:39 PM »
When you put your new Weber on were you able to do away with all the smog stuff?  Could you explain what you needed and what you did not need anymore as far as emissions stuff.  Does the engine still need the ECU with the Weber?
SkipTLoo
« Reply #5 on: February 16, 2008, 10:41:28 PM »
I really dont know what I should buy.......all I know is I need a new carb!!!!  I have heard to upgrade to an after market carb but dont know if I nees E choke or M choke??? either one would work for me!!!  Just thought the E choke would be better that the M choke.... If you have any ideas let me know.....
Thanks for all you feedback!!!!!!!!   SkipTLoo
sanjuansheriff
« Reply #6 on: February 17, 2008, 12:48:39 AM »
Skip,
Don't forget Weber also has a water choke version for your Samurai also... Same as your stock carb.
Dennis
rascott
« Reply #7 on: February 17, 2008, 08:41:13 AM »
skiptloo
i went for the manual choke version. i like basic.
richard
still looking for a shorter replacement throttle cable.
SkipTLoo
« Reply #8 on: February 17, 2008, 10:04:09 AM »
Doze the ZUK have a water choke on it now??? or is it as easy to install???
rascott
« Reply #9 on: February 17, 2008, 10:41:44 AM »
skiptloo
i'm sure yours has a water choke.
the kit is easy to install- should come with enough instruction.
i am also using my stock air cleaner. i'm sure the 'weber" one would work fine, i just wanted the engine to look stock.
richard
SkipTLoo
« Reply #10 on: February 17, 2008, 05:09:14 PM »
alright i think u have helped me out!!!!! im going to go buy a h2o weber carb!!!!
« Reply #11 on: March 05, 2008, 06:24:38 PM »
Hey if we could continue this a little longer. I am very curious about the emission and vacuum stuff concerning swapping to the weber. Here in Western Washington I am going to have to pass the emissions for a couple of more years.
Offline SkipTLoo
  • 26
« Reply #12 on: March 05, 2008, 06:46:34 PM »
I could not tell you about emissions.... I registered mine out of town to bypass that......But when I tried I failed!!!!!  Then tried to do a quick tune up and went back and still Failed!!! So thats when I decided to register mine out of town... I don't know if should rebuild mine or get a weber????  Aftermarket carbs seem to work for alot of people...but I don't have three bills right now.  But my carb is flooding out....when I push the gas pedal down all the way it bogs down...so I hope it is the carb ???
