Reverse light switch????
  • 2248 Views
MaD.72
« on: February 17, 2008, 08:55:59 PM »
I have a 97 sidekick and i want to change the switch on the tranny, does anyone had done it before?? and where i can get it, dealer or autopart store and is it expensible??
Thank's
Offline da_tub
  • 307
Re: Reverse light switch????
« Reply #1 on: February 17, 2008, 09:34:28 PM »
it's pretty easy to do , it just screws out.. with the help of a wrench..and one wire if i remember correctly..part is cheap also even cheaper from pick and pull..
91 four door ,and some stuff
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #2 on: February 18, 2008, 01:45:29 PM »
If you can get your hands in there, it's a piece of cake.  You could try a standard auto parts store.  I sold a few when i worked for Schuck's Auto and Advanced.
One from a junkyard would probably work too.
Sometimes the wires can get messed up, and it's not necessarily the switch.  Make sure you check out a few things before you just replace it.
1993 4-door Sidekick
4.24:1 t-case
MaD.72
« Reply #3 on: February 18, 2008, 07:35:12 PM »
the only way to turn them on is if i hold the shifter down in reverse!
Offline JoeCool
  • 164
  • Carpe Noctum!
    • cardomain
« Reply #4 on: February 18, 2008, 08:29:41 PM »
Yup, sounds like the switch is dead, the wire on mine had coroded till it broke off. like $30 from the dealer.
5psi turbo '90 2dr 5spd 8v Tracker, Lt235s, 1" spacers, Rocker Rails, Warn Hubs, Custom half door,--GONE!
New, Sammi Tintop
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #5 on: February 18, 2008, 09:33:13 PM »
I had to change mine to, the hardest part was getting the connector pluged in again. I used a short(5" long) adjustable wrench, and I unplugged it from above. You can see it if you look from the drivers side, looking down on the tranni, looking between the firewall and the exhaust manifold. I could just reach my arm in there to unplug it with one hand, then I used the wrench from below, drivers side. Try to clean off any grease before you take it out so you don't get dirt falling in the hole.
