toyota axles
  • 1881 Views
dres0081
toyota axles
« on: February 19, 2008, 02:26:56 PM »
i am trying to decide if i want to go with toyota axles on my samy. I already have yj springs my next step is gearing the transfer case to 6:5 1 and keep the stock axles. Does anyone know if I am going to run into trouble when trying to go to toyota axles.
MaD.72
Re: toyota axles
« Reply #1 on: February 19, 2008, 02:32:39 PM »
Check here if you want to put toy axle...
http://www.sky-manufacturing.com/
Offline j2custom
  • 197
  • Suzuki's rule!
Re: toyota axles
« Reply #2 on: February 19, 2008, 05:29:18 PM »
I found the swap to be very straight forward.  The front axle is a bolt in and I was able to use the stock front driveshaft with spacers (I had to redrill the toyota flange).   Part of the reason is I used the Trail Tough YJ spring mounting kit with the YJ springs kicking the front axle forward enough for the longer 3rd member of the toyota.  The rear was easy and I didn't have any vibration from the offset t-case to centered rear axle.  I did run a rear torque bar for spring wrap.
I wish I would have kept that rig... HTH
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
dres0081
Re: toyota axles
« Reply #3 on: February 19, 2008, 05:38:18 PM »
I was wondering how much lower the gearing is the toyota axles and if it would be too low with 6.5:1 t-case gears. dont have the t-case yet but dont want to get the gears first and end up having to change them again to accomidate the yota axles
MaD.72
Re: toyota axles
« Reply #4 on: February 19, 2008, 05:49:15 PM »
I find 5:71!!
