tire sizes on ur rig
  • 45 Replies
  • 9942 Views
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« on: October 19, 2004, 05:50:33 AM »
i was wondering what type of wheeling every one does and what type and size tires they use.
i run alot of mud, water, sand, and ossasionally go rock crawling. however i have found that my 31" tsl swampers need to be 34 or 35 to run 4and 5 calss rock trails.
also does anyone run the kicker 3 daul case set up.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline Urban_offroad
  • 47
Re: tire sizes on ur rig
« Reply #1 on: October 19, 2004, 06:10:14 AM »
I'm running 31 procomp muds with 3" suspension and 2" body, and I do just fine pretty much everywhere. I was up at Apex mountain here in BC and ran a class 7 trail rating for the jeep jambeoree. Made it half way without much problem. Only thing that stopped us from going further (jeeps and toys included) was it was very slick and nobody really wanted major damage being everyone was really far from home and wanted to drive it back  ;D ;D ;D. But some of the rocks definately needed 35" tires or bigger. I drove out of there with a scuffed rear diff and a dented gas tank... I have belly skid plates. But On the other hand I feel us zukis being nice and compact I can pick a nice line and drive around the major rocks.
Here are some of the pics..
http://www.hot4x4.ca/gallery/view_album.php?set_albumName=album155&page=1
« Reply #2 on: October 19, 2004, 06:24:11 AM »
We run just about any thing here (no sand though). A single trai in tellico will have loose dirt, mud rock hills, you name it. I run 33x12.50 Goodyear MTR's. Alot of people run these in the area and they have great bite in most any terrain.
Offline Whipp
  • 62
« Reply #3 on: October 19, 2004, 07:07:07 AM »
I typically run moderate trails.  The terrain is usually dry, rocky, with some loose, mogully, steep hills, little mud and no sand.  And snow in the winter.
For tires, I have 30x9.50 BFGoodrich Mud-Terrain T/As.  Not the largest tires by any means, but I haven't broken anything yet (fingers crossed), and my gearing isn't too far off.
- Craig
1989 Sidekick with 3" Calmini suspension, Old Man Emu Struts, Calmini header and exhaust combo, A/C on board air.
- Sold to my brother!
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #4 on: October 19, 2004, 08:05:10 AM »
Great pics 8) Where is Whipsaw-Nickelplate located? The date says July 1-4, 2004 and you guys are dressed like it's winter. ;D
Offline 1bigtracker
  • 3409
« Reply #5 on: October 19, 2004, 08:37:37 AM »
i run deep mud and have 34/9.50R15 swampers.  work well but i will be doing some testing in the spring with some next rubber.
stu
Offline Freezuk
  • 61
  • Flopped it the day I got it!
« Reply #6 on: October 19, 2004, 08:38:33 AM »
I have a spring over and a shackles, I'm clearing then 33x12.50x15lt's.
I'm clearing the front tires by 10 inches and the rear tires by 9 inches.
« Last Edit: October 19, 2004, 08:38:56 AM by freezuk »
Spoa, geared & locked, t-case gears, hybrid rear axle
  • 47
« Reply #7 on: October 19, 2004, 08:39:02 AM »
It's up at Apex mountain, it's around Penticton, British Columbia. It was cool and raining. The main reason we where bundled up was that the place was just crazy with misquitos, ate everyone alive with or without bug spray.
Offline explosivo
  • 3157
« Reply #8 on: October 19, 2004, 08:46:41 AM »
I run 33x13.50 TSL LTB's. Need to find some stronger front end stuff :(
omghi2.us[/url]
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #9 on: October 19, 2004, 11:11:58 AM »
i run 31"x10.5" on 15"x8" rims. have had no problems so far, and the MT/Rs are a pretty good all rounder, as there is loose dirt/gravel, mud, sand, hills (loose and rocky) and mud. did i mention mud as well?
anyway, where i am, there's not a whole heap of bog rocks and boulders as you would find in rock crawling, so obviously i dont do it, i'd love to though.
i should've got 32"s, as i have enough room for them to fit and not rub on everything. but for what i'm doing, my vit is sweet.
Offline 92Sidekick4x4
  • 1456
« Reply #10 on: October 19, 2004, 11:35:19 AM »
i got 30x9.5 on stock wheels, these tires fit when i ahd no body lfit in my truck they fit good.
« Reply #11 on: October 19, 2004, 11:37:16 AM »
6"inch lift, 32x10.5/15 SuperSwamper Radials and 15x8 rims and some fender trimmings ;D
I like the Swampers for the wheeling I do.
Mud
Rocks
Dirt
Haven't tried sand. Fraid I might dig me a hole to Japan ;D
Offline azrocktrash
  • 121
« Reply #12 on: October 19, 2004, 02:37:13 PM »
i run 33x9.50 bigO xts on 8x15 crawlers with spoa 2 s/r and added leaves to stock springs.
 and around hear it's mostly rocks. ;D
     AZ
87 zuk,84 sj410  4 sale
come on,it' only sheetmetal!!
BODY DAMAGE IS ALWAYS AN OPTION
  ~Life begins,where the pavement ends~
Offline tracker8wr
  • 568
    • my home page
« Reply #13 on: October 19, 2004, 02:57:27 PM »
thax for all the info on the tire sizes felas. i think i am going to put on a set of 33 x13.50 on some 10" rims. thanx again.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline explosivo
  • 3157
« Reply #14 on: October 19, 2004, 04:51:20 PM »
Get some stronger driveline components first. I cannot stress this enough.
omghi2.us[/url]
