Samurai as a tow vehicle
  • 2274 Views
tooljunki
« on: February 21, 2008, 05:48:08 AM »
I am thinking about getting a Samurai as a tow car for my motorhome & wondering if there's anything I should know about before doing it. I had an 87 when it was new & just loved it. Is there any particular problems I should look for on one thats got 90-100+ thousand miles on it? Any comments or advice would be appreciated. Glen...
Offline tipover
  • 422
Re: Samurai as a tow vehicle
« Reply #1 on: February 21, 2008, 10:43:25 AM »
I have towed a samurai all over the west behind my motor home.  When I got it is had 155,000 miles and put a rebuilt motor and tranny, and never touched the t-case. Just follow the flat towing directions, except I never worried about the "let it run every 200 miles" to lubricate the t-case.  I just went.  I also built one for my inlaws with about the same miles without rebuiolding the t-case.
Be carefull about putting lifts on these things.  because when you flat tow the front driveline is spinning.  so if you have a front driveline vibration, it could cause premature failure in the front drive train.  If anything fails while towing, you won't know untill to late.
I take the Steering wheel lock pin out so I don't have to keep the key in it to unlock the steering.
You did not say where you are from so, but I would get an EFI one especially in california as these are  difficult to keep smog 2 legal.
I have since replaced my stock samurai with a sidekick/tracker as I needed 4 doors for the kids so now I got a sidekick and it tows about the same. my inlaws liked it so much they got one too.Mike is a 5 spped and thiers is an auto.  no problems with either.
IF you need any other info let me know.
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
« Reply #2 on: February 21, 2008, 06:23:09 PM »
If you don't put a locker in it will be just fine. would agree with pulling the steering lock as keeping the key in it is a pain.
flat towed mine for 3 years worked great.
neutral is not a true neutral at least in mine with locker in the rear and in neutral would turn front drive shaft.
Just my .02
Happy hunting.
Mean Green Wheeling Machine
tooljunki
« Reply #3 on: February 26, 2008, 05:32:35 AM »
Thanks for the info, but I'm not sure what a locker is...
Glen
« Reply #4 on: February 26, 2008, 09:43:17 AM »
http://auto.howstuffworks.com/differential.htm
I just like linking to that sight.  :)
