GM alternator upgrade.
  • 17 Replies
  • 5948 Views
phloop
Re: GM alternator upgrade.
« Reply #15 on: October 25, 2009, 10:44:31 AM »
Not much, 45 amps max so you know your getting less than that 90% of the time.
Offline dupont#24
  • 48
  • Deer hunter
« Reply #16 on: October 25, 2009, 07:40:53 PM »
one of the best upgrades you will make I would run my kc lights and winch at the same time and it would nearly kill the motor not no more 105 amps 1 battery.
Offline Merlin93
« Reply #17 on: October 25, 2009, 09:58:01 PM »
The stock Samurai alternator is rated at 35A, and the Trackkick around 55A.  If installing a larger alternator than the Trackkick, just remember to run a new, separate heavy alternator-to-battery charge wire (#6 or larger) directly to the battery (+), bypassing the now-too-small OEM fusible link. [You can simply tape off the old alternator wire, for later re-use if necessary.]  If you don't, you will be replacing the fusible link frequently. You could replace the fusible link with a fuse, if you prefer. But do NOT eliminate the fusible link (or fuse) entirely.  It protects against an electrical fire. Just one electrical fire could ruin your whole day.
