Shock boots?
  • 1946 Views
Offline Cwkick
  • 888
Shock boots?
« on: October 25, 2004, 03:57:38 AM »
Do you use the strut covers and shock boots?  Why or why not?
Cwkick
Re: Shock boots?
« Reply #1 on: October 25, 2004, 04:22:36 AM »
Yes, they look cool and add extra weight to the vehicle when they fill up with mud ::) :P ::)
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Shock boots?
« Reply #2 on: October 25, 2004, 03:21:20 PM »
I use the stock strut boot in front cause it works. However in the rear I keep it open. The aftermarket boots tend to fill up with mud and water... as Zig so elegantly pointed out.  ;D
Mike
Re: Shock boots?
« Reply #3 on: October 25, 2004, 03:52:18 PM »
And I thought shock boots
were there to zap you on
the foot for telling lies  ;)
Offline jagular7
  • 1026
  • Jagular7
Re: Shock boots?
« Reply #4 on: October 25, 2004, 04:39:22 PM »
Like others have stated, the strut boot is actually open on the bottom and is longer than the exposed shaft (in stock config). This helps keep the debri limited to and building on the shaft. For the shocks, the stock shocks are the same way, but when you install better aftermarket shocks, most come with a boot which is fitted to the top and bottom of the exposed shaft. This creates a pocket to hold the debri.
You could cut the bottom of the fitted boot. However, it's not rigid enough.
Lenexa, KS
