headlights
headlights
tracker8v4x4
headlights
February 24, 2008, 09:04:17 AM »
my headlights went oout i checked all the fuses and the switch is good because i tapped into another fuse and it works fine then but im not getting power to the fuse is there a circut braker before the fuse if so where is it at thanks
Armour
360
Re: headlights
February 24, 2008, 09:31:54 AM »
best bet would be to get a wiring diagram and trace the wire. It has corroded or broke somehow. might be in the back of the fuse panel
89 Sidekick. 33's. Lincoln Locker,4.24 T Case, 5.13 gears. Warn M8000 winch.
crikeymike
713
Local to Western Washington?? Visit WAZUKS.com
Re: headlights
February 24, 2008, 10:59:10 AM »
Could be a ground that you may have disconnected accidentally, or the connection has broken somehow.
1993 4-door Sidekick
4.24:1 t-case
WAZUKS member - visit
http://www.wazuks.com
