body lift instalation how exciting lol
  • 12 Replies
  • 2950 Views
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« on: February 24, 2008, 03:21:39 PM »
so  all of you guys recomended  the sky 2" body lift and im probably  going to go with that, but how long was your guys installation, doesent matter the size lift just how long did it take u? and somethings should i should be prepared for.  any help would be great and if you had any direction wit you on hand so i take take a look that would be cool to. thanx
Offline ROSS
  • 1412
Re: body lift instalation how exciting lol
« Reply #1 on: February 24, 2008, 04:12:34 PM »
spray all bolts with a good penatrating oil for 2 days . makes it alot easier
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #2 on: February 24, 2008, 09:21:11 PM »
WD40
big_kountry21
« Reply #3 on: February 24, 2008, 09:30:06 PM »
yeah wd40.... a couple of cans should do. lol i'm takin a break.... i'm putting on my 3 inch. right now.
Offline ROSS
  • 1412
« Reply #4 on: February 25, 2008, 06:53:10 AM »
I like to use PB BLASTER.  You can get it at any auto parts store . works the best
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #5 on: February 25, 2008, 09:58:36 AM »
sick tell me how it goes mines a 94 4 door.  but any of these body lifts work with the suspension lifts right?
Offline bzzr2
  • 1011
« Reply #6 on: February 25, 2008, 10:24:04 AM »
the body lift and suspension lifts have nothing to do with each other.   any combination of body and suspension lifts will work on your rig.
09 taco reg cab short box 4x4
jplowman2005
« Reply #7 on: February 25, 2008, 01:02:27 PM »
get a 4" piece of 2" pipe to extend the hose from the gas tank to where you put fuel in....heres a link i found when i was looking...  http://forums.off-road.com/suzuki-geo-all/46591-installing-body-lift-help.html
Trackin_Tracker33
« Reply #8 on: February 25, 2008, 01:08:11 PM »
This is the best step by step instructions that i have found for a BL  if needed..http://www.izook.com/tech/tracker/kicklift/bodylift.htm
hope it helps... im doin my Rocky-Road BL in two weeks
phloop
« Reply #9 on: February 25, 2008, 07:38:53 PM »
If Sky has not updated his instructions since I installed his 1" kit when you do the pass. side you need to loosen the fuel fill tube from the body too the tank. I fought with that issue untill I realised what was hanging the body up.
And other than the time fighting with the fuel tube, I think it only took an hour or so to install it.
Offline olija
  • 770
    • Check out my cardomain
« Reply #10 on: February 25, 2008, 10:36:22 PM »
You might need to bend your tranny shifter a little. Spend some time playing around with the shifter boots too, make sure your shifters aren't simply riding the synchros or they won't last long.
phloop
« Reply #11 on: February 25, 2008, 11:15:32 PM »
Not a big problem with the boots as the boots on the body will slide up the shifter shafts.
Offline big_kountry21
  • 415
  • 1 bad mamajama
« Reply #12 on: February 28, 2008, 09:11:54 PM »
i didn't even use the extension for the fuel....... you will have to do some modifying on the air intake..... they don't tell you about that either.
camo 96' trak 16v 2dr 4x4
235/75/R15 MT's 15x8 black wagon wheels
5.13 gears 3" calmini body lift..
