sammi low range case
  • 3528 Views
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« on: October 23, 2004, 11:53:14 AM »
i was told that by reducing the t-case gears in a sammi that it reduces the 2 and 4 hi drive ratio. if so to what. what is the equilivent ring and pinion size.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Re: sammi low range case
« Reply #1 on: October 23, 2004, 01:03:05 PM »
What set ya looking at?  there is about five or six different low ranges on them all with diffrent high reductions, the stock is 1.409 x 3.73=5.25    my 4.16 low rang has a 1.579x3.73=5.88 I think the 6.5 reductions have a 1.75x3.73=6.52 to one final in fourth gear.
Offline tracker8wr
  • 568
    • my home page
« Reply #2 on: October 23, 2004, 01:28:01 PM »
i have 5.12 in my tracker but i'm doing the kicker3 and was trying to find out what the reductions are. i need around 5.80 something. i will be running 35" to 37" tires. i was going to run 33's but i found that there is a company making supertorq CV's that can hand 450 hp. and also axle shafts that handle 500hp. i am running a stock 16 valuve so i think they should hold up.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
« Reply #3 on: October 23, 2004, 02:58:14 PM »
even with a stock sammy tcase your looking at 1.409x5.12=7.21 to one in fourth gear, take a look at the k- 2 from ott it use's a toyota t case on the back of yours that would line up better if your using the stock houseing in the rear, please tell about the axels and what not you plan on using. they make 5.83 gear sets for the tracker.
« Last Edit: October 23, 2004, 03:00:38 PM by mrfuelish »
Offline Bfunk
  • 406
« Reply #4 on: October 23, 2004, 06:25:55 PM »
are you saying the high range in a samurai t-case is not 1-1 ???  Is the sidekick case 1-1 ???  Man I should really know this stuff already :(
Brian
« Reply #5 on: October 23, 2004, 06:40:57 PM »
Yes, the high range of a Sammy T-case
has some reduction, even stock, but the
T-case in a Track/Kick is a 1:1 in high range
Offline tracker8wr
  • 568
    • my home page
« Reply #6 on: October 24, 2004, 07:35:30 AM »
i'm trying to save some cash on the ring and pinion if i can't i mine4 as well buy the ring and pinion and the tracker t-case reduction.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #7 on: October 25, 2004, 04:03:09 AM »
Ok, here are the facts about t-case gears.
RRO
8:1 Hi Reduction          24%
8:1 Lo Reduction         260%
6:1 Hi Reduction          24%
6:1 Lo Reduction         170%
4.16:1 Hi Reduction     12%
4.16:1 Lo Reduction     83%
Trail Tough
6.4:1 Hi Reduction       17%
6.4:1 Lo Reduction      181%
4.9:1 Hi Reduction       16%
4.9:1 Lo Reduction      115%
4.16:1 Lo Reduction    84%
Petroworks
4.89:1 Hi Reduction     18%
4.89:1 Lo Reduction    115%
Calmini
6.5:1 Hi Reduction       20%
6.5:1 Lo Reduction      187%
5.14:1 Hi Reduction     18.3%
5.14:1 Lo Reduction    127%
4.16:1 Hi Reduction     12.2%
4.16:1 Lo Reduction    83.6%
Roadless Gear
6.129:1 Hi Reduction   21%
6.129:1 Lo Reduction  170%
AAPA
6.4:1 Hi Reduction       21%
4.9:1 Hi Reduction       18%
4.9:1 Lo Reduction      118%
4.1:1 Hi Reduction       12%
4.1:1 Lo Reduction      84%
North Coast Offroad
Sells Calmini gears
Spidertrax
Sells Calmini gears
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #8 on: October 25, 2004, 03:04:17 PM »
Id start with the stock sami case and see how that treats you. I had a dual t case setup in my rig for a short time and pulled it out. (long story) I had the Calmini 5.14 to 1 in the sami case with 5.83 in the axles with 35s. By my math that should have been just a touch deeper that stock. Top speed was about 45mph.  ??? I dont know where I went wrong so Im not much help there but knowing that Id say dont go that deep. Seems to me 5.12s and a stock sami case would be closer to stock rpms.
Mike
