Samurai transmission success
  • 9 Replies
  • 4138 Views
sanjuansheriff
« on: February 26, 2008, 06:13:27 PM »
Well I did it.... All new bearings and sycros have been installed and it turns smooth as glass  ;D. My next step is the gasket sealer and bolt'n it together. I have the Blue RTV/RVT? permatex silicon now but I remember reading that some type of gasket maker that is GREY should be used.... Anyone know the brand name of this grey stuff? I can tell that the factory had used a grey colored gasket goop and then when the legendary magical 60,000 mile main bearing went the transmission shop used the brick red colored stuff. It has never leaked in all these years with either of these products.
If anyone is considering rebuilding a Samurai transmission I would highly recommend doing it... I received lots of great help and encouragement  here which made it all possible and a understanding of my rig that I would never gotten by simply writing a check. Thanks again for the help.
Any thoughts on the gasket material/brand?
Dennis
Offline daddyizzle
  • 728
  • Colorado is still my home!!
Re: Samurai transmission success
« Reply #1 on: February 26, 2008, 06:31:38 PM »
I just used form a gasket 1B. I don't know if it's correct but it hasn't leaked in 6 months so far. I just put a very thin layer on both surfaces. Just smoothed out with my finger and put it together. Don't use too much because you don't want it breaking lose and getting in a bearing :o so I've heard.  Be sure to lube the front shaft area so your throw out works right, also your slip yoke shaft and splines so  you don't snag your rear seal on the transmission. Nows a good time to change your rear main seal if it looks or feels stiff. At least I did since it's right there and Napa sells the seal.
-Adam ;D
« Reply #2 on: February 27, 2008, 05:49:19 PM »
Thanks izzle,
Last night after replacing all the bearings I decided to wait for today before closing and bolting it together.... Boy I am happy I decided to wait. I found a C-clip under a shop towel... I rechecked the main gear assembly and found that I forgot one of them in my hast... What a bonehead.
Offline ROSS
  • 1412
« Reply #3 on: February 27, 2008, 05:58:37 PM »
thats the way I felt after my first T-CASE i've done 10 or 12 since
« Reply #4 on: February 27, 2008, 06:42:42 PM »
Ross,
I don't want to do mine again for another 175,000 miles... BUT I sure would like to do another as the mystery has been lifted.... Would it be wrong for me to hope that my budd's Sammy tranny fails so that I can help rebuild it?
Offline ROSS
  • 1412
« Reply #5 on: February 27, 2008, 07:49:21 PM »
he might not much care for that
Offline MaD.72
  • 183
  • It's not what you buy, it's what you built!!!
« Reply #6 on: February 27, 2008, 10:15:48 PM »
Does anyone know where i can find a service manual, that actually show how to rebuilt a tranny for a 97 kick
Thank's
Offline brawnyrebel
  • 131
  • i've cought a case of samuraitis
« Reply #7 on: February 28, 2008, 01:55:12 PM »
Ross,
  If your near Ky you can help me do one.
If its not broken, break it
« Reply #8 on: February 28, 2008, 02:18:47 PM »
I don't think Washington state is to far from Kentucky.... is it?
Offline brawnyrebel
  • 131
« Reply #9 on: February 29, 2008, 03:20:25 AM »
  Nah. Whats a 30 hr drive between friends.
