Samurai flywheel question
  • 10 Replies
  • 5811 Views
« on: February 27, 2008, 05:41:50 PM »
I called over to NAPA just now to get a price for resurfacing my flywheel. I was told that Samurai's have a two step flywheel and would require more money ($50)..... Does this sound about right?
I live on a Island and NAPA is the only game in town... This particular store has a reputation for over charging so I thought I would check with you guys.
Thanks,
Dennis
Offline daddyizzle
  • 728
  • Colorado is still my home!!
Re: Samurai flywheel question
« Reply #1 on: February 27, 2008, 06:10:49 PM »
I think I payed $35.00 at a car quest. I may be mistaken. I assume you are putting in a new clutch. Otherwise I don't think it's worth resurfacing the flywheel for the old clutch. While you have it off though, there's the rear main seal.
-Adam ;D
Offline takai
  • 907
« Reply #2 on: February 27, 2008, 06:30:23 PM »
Is the flywheel really bad or is it just glazed? You might be able to take a sanding block with some 400 grit sandpaper on it. I have done this on a couple of occasions on several rigs. Just lightly run the sanding block over the flywheel until the shine has is gone.
Just a thought.
'Cause, I am to misbehave.
« Reply #3 on: February 27, 2008, 06:32:48 PM »
Adam,
Yes... I have a new clutch and rear seal    :angel:   .... I was just thinking, do you need to drain the engine oil before removing old seal? I kinda have this vision of running around looking for bucket as the oil pours out.  :-\
« Reply #4 on: February 27, 2008, 06:37:37 PM »
Takai,
I haven't gotten around to pulling it off yet so I don't have any idea as to what it looks like.. That is a good idea about just sanding it as the old clutch was working fine before the tranny went south.
Do you know if this has a two stepped surface?
Thanks
« Last Edit: February 27, 2008, 06:45:54 PM by sanjuansheriff »
Offline blknight87
  • 417
« Reply #5 on: February 27, 2008, 08:09:02 PM »
here's my 2 pennies.....
use a heavy grit emery cloth, and the 2nd step is a finer emery cloth.....  makes sense to me. :-\
first a good rough up to clean, and then a finishing smoother....   ??? idk tho...  i have only done like a dozen or so....  use emery cloth... not sand paper...  good thought tho...
87 sammy-JX
U4WDA/IBZK
1.6 8V w/ MY-SIDE2-44mm SE carb
Thorley Header
Rebuilt trans, and t-case w/6.5-1's
SPOA 6"s w/ Rancho springs
275-85-15's buckshot mudders
Rino Line
RIP "BLKNIGHT" FOR YOU ARE MISSED
Offline ROSS
  • 1412
« Reply #6 on: February 27, 2008, 08:31:46 PM »
yes . its 2 stepped
« Reply #7 on: February 27, 2008, 08:54:38 PM »
Thanks.
Offline ROSS
  • 1412
« Reply #8 on: February 28, 2008, 06:43:33 AM »
you'll understand why they call it that when you look at it
Offline takai
  • 907
« Reply #9 on: February 28, 2008, 06:45:27 PM »
I would do the same thing if I ever had emery paper around. I never seem to have it around when I need it.  ;D
« Reply #10 on: February 28, 2008, 07:21:00 PM »
Bring yours over... I have lots of emery cloth.
