shackle basics
  • 13 Replies
  • 5293 Views
Offline baltz526
  • HUNTING IS WHY
shackle basics
« on: March 01, 2008, 11:51:52 AM »
 i have found a suzuki shackle supplier, they have 3/4" lift, 1 3/4" lift, 2" lift. i'm guessing for my 87 hardtop i need a 2" set for the front and a 1 3/4" for the rear for a level ride. is this the case or do i need the same on all 4 corners. i plan on also putting a new set of stock springs on it at the same time. just searching for tire clearance to run chains on 235,75/15 tires. real chains
« Last Edit: March 01, 2008, 11:02:20 PM by baltz526 »
LAPINE OREGON
Re: shackle basics
« Reply #1 on: March 01, 2008, 04:34:55 PM »
If it were me I would go with a smaller tire for the winter and go to the 235's for the summer and forget the shackles.
Offline Amilla
  • 1076
Re: shackle basics
« Reply #2 on: March 01, 2008, 06:30:26 PM »
Block lift...Front and rear! ::)
Amilla
Offline baltz526
  • HUNTING IS WHY
Re: shackle basics
« Reply #3 on: March 03, 2008, 08:17:45 AM »
i'm not doing a lift  :P EVER  :police: search has nothing relevent, i just get non related topics after the fist few.
LAPINE OREGON
Offline mic
Re: shackle basics
« Reply #4 on: March 03, 2008, 09:06:39 AM »
The shackles are not a lift?? 2" shackle lift?
91 Tracker Calmini 3+3 31x10.5 swamper ssr
88 samuri 3" body 2"susp. 31x12.5 boggers sold
03 super duty daily work truck $$$$gas
Re: shackle basics
« Reply #5 on: March 03, 2008, 09:12:26 AM »
Shackles change the angle of your drive lines, your front diffs steering will be affected, and your creating a weak point on the frame where your longer shackle hooks to it with allot more leverage also allowing your springs to swing.
Re: shackle basics
« Reply #6 on: March 03, 2008, 06:45:45 PM »
If you are looking for a bit more height just get an add-a-leaf kit from one of the suppliers advertised at the top of the forum, they all do quality work.  It will give you 1 to 1.5" of lift and not screw with your drive line angles like a straight shackle lift will.  Another issue with shackle lifts is you only get half the lift of your shackles, a 2" shackle lift only lifts your rig 1".  The only advantage I see to different shackles is you can get heavier duty ones so they don't bend when going off-road.
I prefer Hawk Suzuki (www.hawksuzukiparts.com) as I have never had any problems with their quality of service and parts.  :)
« Last Edit: March 03, 2008, 06:47:47 PM by Drone637 »
Offline baltz526
  • HUNTING IS WHY
Re: shackle basics
« Reply #7 on: March 03, 2008, 08:23:58 PM »
thanks, so the 3/4" shackle with a new set of 4 stock spring, is what i think i'll order. a new set of shocks and if i can not run chains on the front, with the 235/75/15 p 8"x28.5" that are on the rig, i'll drop tire size to 215/75/15 8"x 26.5" approx
LAPINE OREGON
Offline Cuthulu
  • 384
Re: shackle basics
« Reply #8 on: March 03, 2008, 09:02:10 PM »
Add to that the pants wetting feeling the first time you get off camber and they decide to unload.  That my friend is an experence with some pucker factor.   :o
Re: shackle basics
« Reply #9 on: March 04, 2008, 04:51:30 AM »
If you're going to replace the springs and shocks anyway then why not buy a 2" lift kit. Then you get the clearance without the bad steering and you won't ruin your new springs.
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
Re: shackle basics
« Reply #10 on: March 04, 2008, 07:32:27 PM »
Here is a pic of my 88 Samurai with 2 inch longer than stock shackles and 235 inch tires
I drove this daily like this for almost 2 years with out any issues. if you keep it at 2 inch longer or under it effects less.
and I wheeled it at most of western washington wheeling spots
tahuya, elbe, and Evans Creek
anyway this gives you an idea of how much clearance you can have.
PS I'll sell you my used shackles off my Samurai for 75$ plus shipping.
they are from Rocky Road.
I went to a wrangler spring setup.
If not no biggie :)
« Last Edit: March 04, 2008, 07:38:24 PM by bashzuk »
Mean Green Wheeling Machine
Offline baltz526
  • HUNTING IS WHY
Re: shackle basics
« Reply #11 on: March 04, 2008, 09:06:40 PM »
 i trimed the front bumper brackets back as far as the pipe mount, gained 1" on turning. so the tire rub is gone. fit chains and tested rear clearance. everything cleared, but it is minimal. next time the cash cow craps i'll order the new stock leaf spring. and get rid of the flat ones on it. i expect about 1 1/2" when it returns to stock height. chains will probably still rub on front, but the rear will be fine. one of the areas i hunt, gets snow over greasy clay. with chains on all 4 i can get around.
LAPINE OREGON
Re: shackle basics
« Reply #12 on: March 05, 2008, 04:35:41 AM »
Front springs are pretty flat from the factory. If they aren't inverted then they're probably OK.
Offline baltz526
  • HUNTING IS WHY
Re: shackle basics
« Reply #13 on: March 06, 2008, 09:48:47 PM »
yes they are getting inverted and the bushings are shot.
LAPINE OREGON
