lift kit and tires
  • 11 Replies
  • 6243 Views
Offline deplin
  • 24
lift kit and tires
« on: March 01, 2008, 12:34:37 PM »
Is there anything out there that tells you what size tires and rims you can fit with what size lift kit.  I have a 96 Sidekick 4wd 4 door.  I am looking to put either Calmini's 3 inch body lift or possibly the 3 inch suspension and the 3 inch body lift.  So far I have found nothing that tells me what size tires I can fit with either one.  I am looking to have a little wider of a rim with a little different offset of rim that will give the truck a little wider stance and better stability.  My tuck has P215/65R16 with 6X16 rims.
Offline Amilla
  • 1076
Re: lift kit and tires
« Reply #1 on: March 01, 2008, 12:47:13 PM »
This question comes up all the time, there should be tons of information on this site...
You just have to use the search bar.
Good luck
Amilla
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
« Reply #2 on: March 03, 2008, 07:17:08 AM »
well now....wouldnt that just be too easy?? seems like alot of the NEWER POSTS on here all need to be answered like this!!! aahem....irishbill....bigkuntry??
Offline kickscrawler91
  • 23
« Reply #3 on: March 03, 2008, 08:19:54 AM »
Calmini has a tire chart on their web site. When you click on the suzuki page, the right side of the screen is shaded in black, there should be a tire chart in that list.
Rocking the Kicks!!!
Offline deplin
  • 24
« Reply #4 on: March 03, 2008, 08:29:23 PM »
No tire chart that I can find on the Calmini website.  Maybe it is my browser but I am thinking not.
Offline deplin
  • 24
« Reply #5 on: March 03, 2008, 08:41:26 PM »
I should have mentioned.  I ordered the Calmini 3" body lift kit today.  In the future I would like to order the 3" suspension lift kit.  I would like a little wider stance to increase stability.  I would like to find a rim and tire package that would be compatiable with both.  My plan is to go with a wider rim and tire package with an offset on the rim to bring it out about 2-3 inches out from the wheel well then stock.  I am wondering if there is any place to find that info.  I want to get the rims and tires prior to the 3" suspension lift.
Offline deplin
  • 24
« Reply #6 on: March 04, 2008, 08:07:52 PM »
Any help would be appreciated.  I find the search very cumbersome on this forum and I would appreciate any info.  Thank you.
Offline idaholwb
  • 772
« Reply #7 on: March 04, 2008, 08:34:53 PM »
 It kind of sounds like you have a Sport, especially if you have stock 16" wheels and tires on it. If so, you are stuck doing something like an Old Man Emu and body lift. Unfortunately no one makes a suspension lift for the Sport models at this point that I'm aware of. I might be looking into seeing what it would take to put together a real lift for one of these later this year. I'll let ya know what I can figure out.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline deplin
  • 24
« Reply #8 on: March 04, 2008, 08:53:41 PM »
I found on Calmini's website a 3 inch suspension lift for a 4 door.  I ordered the 3 inch body lift and I am looking for a new rim and tire combo that will work with just a 3 inch body lift.  In the future I would like to add the 3 inch suspension lift.
Any idea what size tire and rim will work or where I can find this info.  I want the tire to be about 3 inches outside of the wheel well.  You were right it is a sidekick sport.  Good call.  I am new to the tracker sidekick stuff.  Thanks for the info.
Offline ROLLOVR
  • 30
  • U.S.A. Lawn Gnome Liberation Front TN. Chapter
« Reply #9 on: March 05, 2008, 06:35:47 AM »
Here you go, Link!   :D
http://www.puresuzuki.com/tire_chart.htm
Or from the Calmini Site:
Suzuki Sidekick / Vitara / Geo Tracker
Equipped with 3" Suspension Lift System
Tire Size 30" x 9.5"   Rim Size 15" x 7" / 15" x 8" Backspacing 3" - 3.5"
Equipped with 6" Combo Suspension System ( Suspension Plus Body Lift )
Tire Size 32" x 9.5"  Rim Size 15" x 7"  Backspacing 2" - 2.5"
These are the Maximum that Calmini Recommends - However, I found that with some Wheel / Rim Manufactures,  3 " or greater backspacing may contact the brake caliper. I have 3" backspacing with the Eaton Heavy-Duty Steel Wheels and had to grind a little of the caliper casting to get it to fit. Just something you should consider when choosing a wheel or rim, the way it's manufactured with the dish from the lugs to backspacing. (My Wheels are 15" x 8" with 3" Backspacing and 32" x 10.5" TSL  Swamper Radials. If I had to do it again, I'd go with 30" or 31"tires with a wider tread width on these rims. Oh, and I have the Calmini 3"+3" or 6" Suspension Combo lift. FYI)
« Last Edit: March 05, 2008, 11:07:55 AM by ROLLOVR »
Warning; Do not drop acid and go Gnoming, For lest ye think thou are the Glorified Messiah and Savior of all Gnomes.
Equation ( Dropping Acid + Lawn Gnoming = A Visit from the Man )
Offline jeff1997
  • 1228
  • 27
« Reply #10 on: March 05, 2008, 02:37:28 PM »
My coil spacers fit a Sport and will give you another 2" of lift. I have a 97 4dr. Sport with a 3" body and my 2" spacers. I run 31-11.5-16 Super Swamper LTB's.
3" Masterkit1 body lift
Custom strut spacers
Offline deplin
  • 24
« Reply #11 on: March 05, 2008, 03:23:41 PM »
Thank you for the link Rollovr.  For some reason I could not find it before.  Jeff.  What is the cost of your spacers?  Will it change the ride characteristics of the vehicle and if so how?  Do you have a website?  What rims do you run on your sport?  What backspacing are they?  Thank you in advance for answering all my questions.
