Rear axle upgrade?
  • 2285 Views
Offline BIG DOG
  • 105
Rear axle upgrade?
« on: March 02, 2008, 05:10:10 PM »
When you guys upgrade the rear axles in a sidekick/tracker You would be deleteing the rear speed sensor for the rearend.Without this sensor won't the abs brake light come on?I have the brake light on on my rig ...brakes seem to work fine !! If I pull up the brake lever the light will get slightly brighter.I have pulled all the sensors except the rear on the dif and the whole module..Is there a way to cheat the rear sensor ? What else should I look for I'd like to get the light out but cheaply as like I said the brakes seem to work just fine.
Thanks!
Some of the dumbest people I know seem to know everything.........Funny about that!
Offline BIG DOG
  • 105
Re: Rear axle upgrade?
« Reply #1 on: March 04, 2008, 02:50:20 PM »
Nobody had any problems with this?
« Reply #2 on: March 04, 2008, 02:52:21 PM »
I upgraded mine, but an 89... No ABS. Sorry no help here.
Offline erik the red
  • 174
    • Cascade Adventure Guides
« Reply #3 on: March 04, 2008, 06:11:37 PM »
What did you upgrade to?
1996 Geo Tracker
1987 Suzuki Samurai soft top
1987 Suzuki Samurai Tin Top
1972 Suzuki LJ20V
« Reply #4 on: March 05, 2008, 04:42:45 AM »
This has come up before. IIRC the solution is to unplug/remove the ABS computer.
« Reply #5 on: March 05, 2008, 07:19:18 AM »
Currie Ford 9"
