mileage down the tubes
  • 3641 Views
Offline lowrezolution
  • 292
  • "Get bent!"
« on: March 14, 2008, 04:56:08 AM »
Having an issue with fuel mileage dropping off drasticly.
I've lost about 125 km per tank.
Have changed the o2 sensors.
Checked all the vacuum lines, intake tube etc for leaks.
Changed the t-stat.
I get a real fuelly smell in the exhaust and it's really lazy (kinda bogging)off the start put then pics up half way through first?
Any ideas before I drop large for the dealer to look at it?
Thanks
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
Offline blacknight
  • 987
    • Gonzookin
Re: mileage down the tubes
« Reply #1 on: March 14, 2008, 12:48:57 PM »
sparkplugs or fuel injectors ???
George
Offline blacknight
  • 987
    • Gonzookin
« Reply #2 on: March 14, 2008, 12:50:39 PM »
also pull your sparkplugs and see if they have any discoloring or powder on them.
George
  • 292
  • "Get bent!"
« Reply #3 on: March 15, 2008, 04:21:22 AM »
Thanks B-K.
I thru new plugs in about 5000 k but will yank them for a look.
Is there a way to test the injectors?
Could the fuel pressure regulator be an issue, someone brought that up to me too?
Cheers
Scotty
2001 Tracker LWB
Offline blacknight
  • 987
    • Gonzookin
« Reply #4 on: March 17, 2008, 06:14:32 AM »
For testing the fule injectors. see attached pic
Offline aceluck
  • 30
« Reply #5 on: April 02, 2008, 08:19:06 AM »
Blocked cat?
Offline pepatt
  • 174
« Reply #6 on: April 02, 2008, 11:40:29 AM »
Blocked cat?
That was my thought. My neighbor had a cat clog up on him and it caused the exact symptoms you describe.
pepatt
« Reply #7 on: April 04, 2008, 08:19:33 AM »
Did you make sure they were Iridiums?  GVs can be touchy about which plugs works well, and Iridium can stock.
