Whining at shut off
  • 15 Replies
  • 4317 Views
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
Whining at shut off
« on: October 17, 2004, 01:56:06 PM »
In the last week or so, as soon as I turn off the engine, I get this loud whine kind of noise right after shut off, but dies off right away.  Doesn't even last a second...
Any ideas what could be causing this?
« Last Edit: October 17, 2004, 01:56:23 PM by In_Flames »
Re: Whining at shut off
« Reply #1 on: October 17, 2004, 02:05:39 PM »
Blown head gasket, leaking exhaust
out of the radiator cap
« Reply #2 on: October 17, 2004, 02:08:59 PM »
sounds like you need some cheese to go with that whin  ;D
Offline jerryp58
  • 449
« Reply #3 on: October 17, 2004, 02:24:41 PM »
Fan clutch?
Jerry
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #4 on: October 17, 2004, 03:02:26 PM »
Girlfriend? ;D
Offline zukiboy
  • 42
  • Wheel Forever !!!
« Reply #5 on: October 17, 2004, 03:13:42 PM »
Maybe loose spark plug. :)
88 sami
3"lift 30's
No matter where you are there you'll be
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #6 on: October 17, 2004, 03:54:18 PM »
carb? if you have one.
« Reply #7 on: October 18, 2004, 10:22:19 AM »
Girlfriend? ;D
Oh, you beat me to it  :) :)
Offline TN_Tracker
  • 1113
« Reply #8 on: October 18, 2004, 11:06:47 AM »
Oops :-X ;D
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #9 on: October 18, 2004, 01:11:00 PM »
Thanks guys I'll check for those things...it's really wierd, never did that before.
« Reply #10 on: October 19, 2004, 12:49:16 AM »
Maybe your completely out of oil and it's your rings grinding into the side of the piston wall :o j/k  :P I had a bearing in my compressor go out and it would wine at very low rpm and right when the motor was shut off. It's easy to check, just pull the belt, start it and turn it back off and see if the whine in gone.
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #11 on: October 19, 2004, 10:51:00 AM »
No I don't have a compressor.  I'm going to have to check it out tomorrow when I get home from work.  I sure hope it's the fan clutch.  Does oil leak from a blown head gasket?
mperry
« Reply #12 on: October 19, 2004, 10:57:49 AM »
Not usually. If it's a head gasket, it'd probably be water escaping.
I'd guess you'll find it's that clutch fan. If not, you might have someone shut it off and watch for what makes the noise. (I had a pinhole in a hose that leaked only on shutoff.  ???)
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #13 on: October 21, 2004, 11:30:32 AM »
Yeah, I had a friend at work shut off my motor and it sure sounded like it was coming from the fan area.  I sprayed some WD-40 but it still makes the sound...I'm going to do some more research as soon as the friggin wet weather stops.
mperry
« Reply #14 on: October 21, 2004, 12:29:38 PM »
I would assume it's the bearing in the fan clutch. A replacement unit is about $90 locally. You can try cleaning the spring, so the clutch works properly. (It may help.)
One person put in 2 longer bolts & 2 nuts, locking it so the bearing couldn't turn. It'll take away 1 or 2 HP, but will stop the noise.
