31x10.5x15
  • 3147 Views
Offline tracker8v4x4
  • 128
    • cardomain
31x10.5x15
« on: March 17, 2008, 01:46:42 PM »
will 31x10.5x15 mount on stock tracker rims?
will they clear my front bumper or will i have to trim it?
will they fit without coil spacers? how much will it take till they rub?
and will the steering stops have to be adjusted?
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: 31x10.5x15
« Reply #1 on: March 17, 2008, 02:28:22 PM »
Yes, but they will buldge out signifigantly and don't expect to corner hard or you could roll  it right off the bead.
Without lift, no they wont clear.
Without some kind of lift, be it coil spacers or body lift, they will rub a lot.
Yes, you will probably have to adjust the steering stops even after you lift it enough to clear.
To fit 31-9.50x15's on my tracker, I used 1.5" coil spacers up front, 2" coil spacers in the back and a 2" body lift and I still had to trim a little and beat back the pinch weld at the back of the front wheelwell to get them to clear. This was with them mounted on 15x8" rims with 3.75" of backspacing. Now the same tires are mounted on stock sammy wagon wheels that are 15x5.5" with around 4" of backspacing. The sammy wagons are the same dimensions as the stock Tracker wheels, but with 1/2" less backspacing. At one point I had 31-10.50x15 BFG AT's mounted on the sammy wagons on my Tracker and they buldged a bit and I had to run lower pressure than I would have liked to get the tread area to flatten out because of the skinny rims. With the lift, trimming and pounding I had done previously, they just cleared.
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
Re: 31x10.5x15
« Reply #2 on: March 17, 2008, 06:35:40 PM »
235's would be your best bet if you dont want to lift it...they work out excellent on the stock wheels also
  • 128
    • cardomain
Re: 31x10.5x15
« Reply #3 on: March 18, 2008, 12:36:15 AM »
yea i have 30x9.5 on it right now so i was wondering if i sould get a lift then 31's if they fit at all
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
Re: 31x10.5x15
« Reply #4 on: March 20, 2008, 01:52:32 PM »
well, i have about 5-5.5" of lift on mine, and im still running 235's....what kinda lift do u have to fit the 30's?? i dont even think i could turn with some wider tires with my rig the way it is
  • 128
    • cardomain
Re: 31x10.5x15
« Reply #5 on: March 21, 2008, 09:02:02 AM »
i dont have any lift with my 30x9.5x15 i can still turn all the way and never had them rub under flex
look at the pic of the 30's on http://www.cardomain.com/ride/2934945
« Last Edit: March 21, 2008, 09:04:20 AM by tracker8v4x4 »
Offline Uncivilized
  • 1469
    • Car Domain
Re: 31x10.5x15
« Reply #6 on: March 22, 2008, 03:40:51 PM »
You should be able to mount a 33x12.5 with that much lift!
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
Re: 31x10.5x15
« Reply #7 on: March 23, 2008, 06:30:36 AM »
ya...im thinkin when my 235's are dead im gonna get some 31's....the thing is such a TURD with my 235's and the steel wheels that i dont even think i wanna go with 33's
