New front wheel bearing. Special tools?
  • 12 Replies
  • 6742 Views
0 Members and 32 Guests are viewing this topic.
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« on: March 18, 2008, 02:21:06 PM »
I need to change a front passenger wheel bearing. I have the parts at home and a lot of tools. But, Is what I had to be in need of special tools? Like very big socket?
Thanx
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline lowrezolution
  • 292
  • "Get bent!"
Re: New front wheel bearing. Special tools?
« Reply #1 on: March 18, 2008, 02:58:08 PM »
A good set of snap ring pliers to get that pain in the ass retainer clip off the end of the cv stub shaft. 19mm wrench and socket , 21mm socket also if memory serves me correctly.
Not to bad a job, have done it 3 times already my self.
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
Offline 4D-SPUDS
« Reply #2 on: March 19, 2008, 11:42:59 AM »
I bought the special tool to remove the Bearing Lock Washer.  Basically it is a large 4-pin socket.  It seems to be unique to the Vit because it is metric.  But I am sure you could also use a hammer and punch to loosen the bearing lock washer enough to remove by hand.
2003 ChevZuki ViTraka: 2.0 L4 M/T, Calmini 2.5", O.M.E. Struts, Spider Trax 1" Wheel Spacer, 30X9.5R15 BFG All-Terrain TA's
  • 292
  • "Get bent!"
« Reply #3 on: March 19, 2008, 12:26:47 PM »
Opps, sorry. Spuds is right, I used a brass punch myself. I also used some nail polish to mark it to help tighten it to the same spot.
2001 Tracker LWB
Offline Fredo
  • 416
« Reply #4 on: March 19, 2008, 05:37:12 PM »
Job done! Realy easy!
But, weird name for bearing maker...
  • 292
  • "Get bent!"
« Reply #5 on: March 22, 2008, 02:51:29 AM »
I should have told you to buy the premium bearings from NAPA as they have a life time warranty on them if you show up with the original receipt. I've already got a freebie when one got full of crap wheeling and sounded evil, no questions asked, just "here's your new bearing n-c".
2001 Tracker LWB
Offline 3stage
« Reply #6 on: April 05, 2011, 11:51:17 AM »
Bumping this old thread..
Anywhere in the US sells that special tool to remove the bearing lock washer?
Offline Novadon
  • 205
  • South Carolina. USA
« Reply #7 on: April 05, 2011, 02:02:28 PM »
Don't forget the bearing nut torque requirements guys!   ;)
Tool info and torque spec in this thread..
http://www.suzuki-forums.com/1g-2001-2006-xl-7/31078-wheel-bearing-bad-can-i-fix.html
« Last Edit: April 10, 2011, 04:39:18 AM by Novadon »
99' Suzuki Grand Vitara, 2.5, 4wd, 5spd.
72 Nova, SB, A/C, Power disk/drum & steering,
03' Honda Odyssey
Offline 3stagevtec
  • 204
  • killing two stones with one bird...
« Reply #8 on: April 06, 2011, 02:48:34 AM »
« Last Edit: April 11, 2011, 02:35:56 PM by 3stagevtec »
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #9 on: April 08, 2011, 11:13:48 AM »
If you're talking about what I think you're talking about...
It wasn't cheap (and the price has increased a few bucks), but this is where I got mine:
http://www.costplustools.com/Kent-Moore-J-37763-WHEEL-BEARING-NUT-WRENCH_p_9505.html
XL-7 front coils
1.5" rear coil spacers
Offline 3stagevtec
  • 204
« Reply #10 on: April 08, 2011, 04:38:48 PM »
^ that's it self.. but $76 bucks!  :-\
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #11 on: April 09, 2011, 07:17:46 PM »
From memory, I'm thinking the hub nuts on the 2nd Gens require 155#s of torque to set them.  That's a whole BUNCH of torque on one nut!  Chevy dealers wanted $35 for one of those round bearing lock nuts a few years ago.  Don't know what they are trying to get for them now... but I'm betting it is a few bucks more.  Crazy prices for some of these onesy-twosy parts..  Used ones from a pick-n-pull work just fine and are a lot cheaper.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
XL-7 front coils
