Best way to tension belts
  • 15 Replies
  • 4854 Views
Offline Speedracer7c
  • 2210
« on: October 19, 2004, 09:57:17 AM »
I just had my belts off this weekend and can't for the life of me get them to stop squeaking at start up. Its driving me nuts! Anyone have any tricks to get them to quit.
Offline 1bigtracker
  • 3409
Re: Best way to tension belts
« Reply #1 on: October 19, 2004, 10:03:56 AM »
take them off. ;D :P
stu
  • 2210
« Reply #2 on: October 19, 2004, 10:05:04 AM »
THanks a-hole.
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #3 on: October 19, 2004, 10:06:46 AM »
put some sort of metal bar between the Alternator when you tighten it back down (I believe the alternator can change the tightness) and use it as a lever.... That's what I do at least.....  ;D
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline Mike71
  • 1449
« Reply #4 on: October 19, 2004, 11:03:45 AM »
dont they have some sort of belt conditioner u can rub on there to stop that??
Offline Chief
  • 678
  • Whaddya lookin at??
« Reply #5 on: October 19, 2004, 09:38:05 PM »
I used a rachet strap. Over the fender, onto the wheel. Not fender friendly, so don't do that unless you don't like your fenders!!!  :o
« Reply #6 on: October 19, 2004, 10:25:05 PM »
A pry bar is the easiest. Snug (dont tighten all the way)the lower bolt that the Alt. pivots on, then use a pry bar to pull the belt tight and fully tighten the upper bolt to hold the tension on the belt. Then finish tightening the lower bolt. If the belt still makes noise it may need to be replaced.
Also check all the bolts that hold the brackets to the engine. I have had some of these back out before allowing the bracket to move causing it to squeek.
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #7 on: October 19, 2004, 10:29:54 PM »
That's what I ment too  ;D I'm just not as good as Zig in explaining things in enlisch (could have something to do with me not being englisch speaking)  :P
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
« Reply #8 on: October 19, 2004, 10:39:31 PM »
;D At least you can get your point across, and understand other languages. I would be lost in any environment that was not english speeking :P
  • 2210
« Reply #9 on: October 20, 2004, 12:46:42 AM »
I just replaced them, and they are squeakin, thats why i'm PO
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #10 on: October 20, 2004, 05:43:42 PM »
You may have to remove the new belts and clean the pulleys.   Kicks and Trackers have troubles with the poor design of their serpinteine belt routing.  This is why new cars have the extra long snaking belts that wrap 180 deg+ of each pulley with idlers and spring loaded tensioners, not just the 120 deg. or so like on the Kick.    The Kicks is done off of the old V-belt design.  This is only marginally sucessful with a flat pulley.
Quote from TN Tracker off of another board on the slipping NEW belt issue:
"I had this problem myself once. Tried everything I could think of including belt dressing spray. Out of desperation I took a product called "Goof-Off" and some steel wool to the pulleys. Installed a new belt and things were quiet from then on. Seems the slipping belt had formed a glaze on the pulleys and installing a new belt without cleaning the pulleys was useless."
Goof off, Denatured Alcohol, or any other non petroleum based cleaning solvent should do the trick on cleaning the pulleys.
« Last Edit: October 20, 2004, 05:58:18 PM by whitfield »
Offline TomKat
  • 211
« Reply #11 on: October 20, 2004, 10:49:53 PM »
    Wow, Ed! You're more articulate than most english speaking people I come across on various BBS's. I'm impressed.
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #12 on: October 20, 2004, 10:53:35 PM »
Thanks  ;D That could have something to do with me being on zukiworld all day long  ;D
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
« Reply #13 on: October 21, 2004, 02:12:32 AM »
stu
No no, he needs some WD-40 ;D
« Reply #14 on: October 21, 2004, 03:32:07 PM »
When one of the pivot bolts falls
out of my alternator, I get a squeal,
so check for 2 bolts on the bottom,
1 front and one rear
