1.6 trail tough conversion problem
  • 2586 Views
« on: March 24, 2008, 05:55:00 PM »
did this conversion and i have had problem after problem. the latest seems to be that my temperature gauge will not work. it has not worked since i did the wire harness and computer swap. anyone else have this problem or know why it wont work? called brent at trail tough and told me that it should work with the new harness. my temperature gauge was working just fine before i did the swap?? anyone know what might be wrong?
Re: 1.6 trail tough conversion problem
« Reply #1 on: March 24, 2008, 06:43:07 PM »
One thing to check is resistance at the sensor.  It may be that your sensor has simply gone bad.
Offline lostsamurai
  • 433
  • LOSTSAMURAI
« Reply #2 on: March 24, 2008, 07:53:49 PM »
I had this prob it was that there was two locations one on the side one on the front try switching it
Offline ROSS
  • 1412
« Reply #3 on: March 24, 2008, 08:16:37 PM »
make sure all ground wires are connected.  very important
he did my harness 5 years ago never a problem. works great
is the temp censor the same one you had in the 1.3 ?????
« Reply #4 on: March 25, 2008, 05:43:19 AM »
Some 1.3 and 1.6 sensors are different. I can't remember which models are affected, I just swapped mine over to be sure.
Offline RHodge
  • 523
« Reply #5 on: March 25, 2008, 06:54:45 AM »
Yeah if you have the 1.3 still try switching the sensor so it matches the rig not the engine
« Reply #6 on: March 25, 2008, 07:03:32 PM »
The 1.3 had a lower t-stat and the guage will read higher if you use the 1.6 sensor and the
1.6 t-stat.
Look for bad connector and or broken sensor blade, common problem,
that and the blade on the sensor gets loose and makes the guage act
wierd.
Offline big_kountry21
  • 415
  • 1 bad mamajama
« Reply #7 on: March 25, 2008, 08:13:11 PM »
my temp sensor broke and i had to replace it..... i replaced it with a 1.3 sensor and it worked fine.
camo 96' trak 16v 2dr 4x4
235/75/R15 MT's 15x8 black wagon wheels
5.13 gears 3" calmini body lift..
