4dr. sidekick. off road capable?
  • 9 Replies
  • 7077 Views
Offline ben_unruh
  • 18
« on: March 25, 2008, 08:44:29 AM »
im looking at a stock 1996 4 dr sidekick sport, and i was wondering if in the future, i could put some 30's on there and maybe a lift, or do they suck for offroad?
Re: 4dr. sidekick. off road capable?
« Reply #1 on: March 25, 2008, 09:18:34 AM »
Unless you like to fabricate or make things 'work', you will be limited in the aftermarket supply for the Sport model. There has been many people that made first generation sidekick aftermarket work on their sports though. I believe a search in this section for 'sport' will give you some ideas.
HTH,
Offline Carnage
  • 2453
« Reply #2 on: March 25, 2008, 10:02:04 AM »
question of the year right there
Offline jeff1997
  • 1228
  • 27
« Reply #3 on: March 25, 2008, 02:46:39 PM »
I have a 97 4dr. Sport with a 2" coil spacer lift and 3" body lift with 31-11.5-16" Swampers. It does not suck! ;D I can't post pics on here but go to ebay and search Suzuki coil spacer and you can see pics of it. The same body lifts and coil spacers will work for the Sport and other Kicks. The 1.8L is a little hard to find parts for but not too bad. It is a big improvement in power though. If you have any questions about my Kick just ask.
3" Masterkit1 body lift
Custom strut spacers
Offline lostsamurai
  • 433
  • LOSTSAMURAI
« Reply #4 on: March 25, 2008, 03:14:57 PM »
I have two trackers (2 door) and a sami all of wich im streching wheel bases, swappin in 16 valve engines and wishin they were more roomy, so basicly im trying to build what your starting with! try it out stock im sure you will be impressed
Offline j2custom
  • 197
  • Suzuki's rule!
« Reply #5 on: March 25, 2008, 07:15:02 PM »
I ran my 1993 4 door Kick in Moab this year and really liked it.  I was able to climb up hills that my Sami couldn't do.  The room is great, I had all my gear behind the rear seat and had room for 4 people.  I blew up the front aluminum housing backing out of Mickey's hot tub on Hells Revenge (duh). 33" tires, 3" calmimi suspension lift, 4:1, spooled rear, disc brakes rear, Hagen widening, blah blah blah.
 This is on a trail 30 miles north of Moab (don't know the name, it was by wild rose trail?)
HTH
2001 Chevy Tracker 4 door 2.0 5 spd 4x4
1995 Geo Tracker 1.6 8V 5 spd 4x4
2005 Tundra Crew Cab Limited 4x4
 It's not what you buy... it's what you build
Offline Carnage
  • 2453
« Reply #6 on: March 25, 2008, 07:20:15 PM »
your kick looks like a land rover in that pic!
Offline big_kountry21
  • 415
  • 1 bad mamajama
« Reply #7 on: March 25, 2008, 08:03:54 PM »
my 2 dr does good but i've heard that the 4 dr are better for crawlin and climbing.
camo 96' trak 16v 2dr 4x4
235/75/R15 MT's 15x8 black wagon wheels
5.13 gears 3" calmini body lift..
Offline olija
  • 770
    • Check out my cardomain
« Reply #8 on: March 25, 2008, 09:37:01 PM »
I have a 4 door (not a Sport though). It rips around pretty good with 31's on it. They will fit if you have proper backspacing on your wheels, at least a 1.5" coil spring spacer lift, and a 2" body lift, and some fender bashing. If you're into more tough trails though, put some gears in it otherwise you will kill the clutch as I have just done. I enjoy the extra space most of the time. The only downside is the breakover angle is a little less than a shorty, but just drive smart and you should be able to handle it.
PS: The 1.8L the Sport has might handle the 31's better than my 1.6
Offline Element
  • 1902
  • LillyKicker
« Reply #9 on: March 25, 2008, 10:34:09 PM »
My LillyKicker is capable.
zUkTAH
U4WDA
