Another 1990 8v 5sp question
  • 2173 Views
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
« on: March 25, 2008, 06:39:14 PM »
well about a hour ago my tracker rolled over 100000 miles and as soon as it turned the cel came on.  i know that there is a switch to shut it off.  Does anyone know where the button is.
Offline lostsamurai
  • 433
  • LOSTSAMURAI
Re: Another 1990 8v 5sp question
« Reply #1 on: March 25, 2008, 07:06:06 PM »
im not sure there is one on the trackers, I just pulled out the dash gauge cluster  and pulled the light bulb :)
« Reply #2 on: March 25, 2008, 07:10:31 PM »
It's said to be behind the drivers side speaker
« Reply #3 on: March 25, 2008, 07:11:46 PM »
There is a reset switch behind your drivers side speaker under da dash. If you cant find it, dont worry, it just a lame ass excuse for the dealer to get you in to pay $50 to have it reset as they try to sell you a $500 service visit.
Offline kubik1981
  • 232
« Reply #4 on: March 25, 2008, 07:13:44 PM »
anyplace preticular behind the speaker
Offline Carnage
  • 2453
« Reply #5 on: March 25, 2008, 07:18:58 PM »
hotrod has a picture
or you can just use the SEARCH feature
Offline SnoFalls
  • 1358
« Reply #6 on: March 27, 2008, 08:21:54 AM »
On a 1990 I believe it will be here
On my 93 4dr it is behind the driver side speaker.
Offline kubik1981
  • 232
« Reply #7 on: March 30, 2008, 07:59:23 AM »
thanks for all your hep i found it.  I had to remove that litte panel under the steering coloum and it was down on the bottom where the dash rolles back
