Pics of my camo 83sj410
  • 2390 Views
Offline 83sj410
  • 46
« on: March 25, 2008, 08:14:41 PM »
Finally learned how to post pics so I thought I would show off my junk. The 1 liter doesn't quite have the jam for the 31" boggers but the 87 Sammi I am building will.I still have to paint the roof I see.
Who knew 45 horsepower could be so fun???
Offline big_kountry21
  • 415
  • 1 bad mamajama
Re: Pics of my camo 83sj410
« Reply #1 on: March 25, 2008, 08:19:14 PM »
it looks sweet.....i want to get some boggers.
camo 96' trak 16v 2dr 4x4
235/75/R15 MT's 15x8 black wagon wheels
5.13 gears 3" calmini body lift..
Offline olija
  • 770
    • Check out my cardomain
« Reply #2 on: March 25, 2008, 08:22:19 PM »
Those tires are way too wide looking. Put some pizza cutters on and it'll be sweet! I like the general look of the truck though. Is that the air intake on the driver's side back corner of the hood?
phloop
« Reply #3 on: March 25, 2008, 08:57:50 PM »
Nice, looks like you could use some wheel spacers and add some of those flairs that TT has. Those 31's do look large, think 35's would be overkill on a Sami?
Offline 83sj410
  • 46
« Reply #4 on: March 25, 2008, 08:59:27 PM »
Yeah those tires are pretty wide 12.5s on 12" rims. I don't actually run those tires it doesn't have the power to turn them. I run 7.00 R15 bias ply Good Years they look like old army tires.I bought the Boggers for the 87 Sammi I am building. They stick out even further on it due to the wider axles, but I bought a set of 6" TJ flares and they will cover the tires up perfectly.The thing on the cowl actually covers the heater air intake. It is different than the Samurai, the previous owner installed it to keep leaves out of the heater.
Offline 83sj410
  • 46
« Reply #5 on: March 25, 2008, 09:09:45 PM »
If you are asking my opinion if 35s are too big for a Sammi I don't think so.The 31s do look big on my 83 I think it would need at least a couple more inches of lift, it has a basic spring over 4.5" lift. My 87 is eventually getting a complete Toyota powertrain on YJ leafs with 5.29s and at least 35s. Otherwise I may as well just stick with Sammi axles.Boggers weren't my first choice, but I got them for $100 a tire. I think they will take too much horsepower to turn and get spinning fast in heavy mud. When I buy bigger tires I think I will go with a TSL type tread. Once you get a Sammi lifted enough that 35s will fit the tires really don't look that big.
phloop
« Reply #6 on: March 25, 2008, 10:14:14 PM »
I was kinda leaning that last remark towards the kick owner that mentioned pizza cutters not you, guess I should have done some quoting on that post.
My Sami has 32'' TSL's now and after I do the YJ swap I am planning on running some narrow 33" boggers unless I decide to do some cutting then I'll go with the 35's.
When you get to building the 87 post up some pic's. And a pic or two of the 410, maybe with the roof painted? ;) :laugh:
Offline lostsamurai
  • 433
  • LOSTSAMURAI
« Reply #7 on: March 26, 2008, 10:09:49 PM »
 they look perfect put the same ones on the sami but 35" who needs horsepower just get gears, I run 35" grip spurs and I never go over 2000 rpm, gears man!
Offline 83sj410
  • 46
« Reply #8 on: March 28, 2008, 08:12:30 PM »
 Sold it tonight for $2500. I needed to buy a good tow rig so something had to go. Will post pics soon of the 87Sammi and 82 sj410 I'm building.
John
