popping/ clunking in the rear end?
  • 1721 Views
Offline Freezuk
  • 61
  • Flopped it the day I got it!
« on: October 18, 2004, 07:13:30 PM »
So i finished all of the mods i plan to do to my sammy, and i drove it tonight for the first time in months. the rear end is making a popping/clanking noise which it did not before, any idea?
Spoa, geared & locked, t-case gears, hybrid rear axle
Offline jerryp58
  • 449
Re: popping/ clunking in the rear end?
« Reply #1 on: October 18, 2004, 11:49:02 PM »
What mods did you make?
Everything tightened down?
Did your driveline angle change?  Any yoke/driveshaft interference issues?
Jerry
Offline 1bigtracker
  • 3409
« Reply #2 on: October 19, 2004, 04:21:46 AM »
you may have a chiped ring, pinoin or spider gear.  if it is only when you turn its a spider gear.
stu
« Last Edit: October 19, 2004, 04:21:59 AM by 1bigtracker »
Offline Freezuk
  • 61
« Reply #3 on: October 19, 2004, 08:35:06 AM »
I just went to talk to my buddy and he told me that because i did the spring over, the u joint is clanking on the driveline, he said I need to put a traction bar on the rear axle to the frame to stop the pinion from rising up when I accelerate..
