Oil leak
  • 1751 Views
Offline reb
  • 195
  • Victim of CRS--Can't Remember Anything.
Oil leak
« on: April 08, 2008, 08:07:33 PM »
Walked back to the Sport in the Wallyworld parking lot yesterday and noticed a dark spot under the rear of the engine.  Got it home and crawled under to check it out and it looks like the rear crank seal has sprung a leak.  How much work is it to replace it?  I have a feeling it is more of a task than I want to take on.  The wallet is probably going to take a hit--I'll just have to tell the wife that we won't be eating out at McD's for a while.
Offline ROSS
  • 1412
Re: Oil leak
« Reply #1 on: April 08, 2008, 08:48:04 PM »
make sure its not the distributor leaking down thrru the bellhousing
Offline Jimiweld
  • 234
    • www.fullfusion.ca
Re: Oil leak
« Reply #2 on: April 08, 2008, 08:56:22 PM »
Or the back corners of the valve cover, I had to change both the valve cover gasket and distributor as Ross pointed out. Power wash all the oil off and have a good look at where it's coming from.
Offline reb
  • 195
Re: Oil leak
« Reply #3 on: April 09, 2008, 11:24:17 AM »
Thanx for the replies.  The 1.8 in the Sport doesn't have a distributor.  The engine is fairly clean--I have put only 20+k miles on it since I bought it from a dealer who apparently cleaned it up.  I see no sign of leaks from the valve cover.  I was hoping it was something simple like a gasket leak or a leaky oil pressure sensor, but I haven't found any.  Haven't found the oil pressure sensor, for that matter.
