REAR DRIVE DISCONNECT
  • 2471 Views
Offline DistantSmoke
  • 62
« on: April 08, 2008, 09:17:14 PM »
Is any one running a rear drive disconnect on their Sammy???
I just ordered one from Trail Tough just wondered if anyone had any thoughts about this product??
You can run if you want but you'll just die tired!!
Offline cj
  • 1276
  • I drive a really big ATV
Re: REAR DRIVE DISCONNECT
« Reply #1 on: April 08, 2008, 09:24:35 PM »
Not yet but it is on the way  :) but it will be a bit before it goes on mine as I need to modify/fab some stuff so that I can use it with the Spidertrax transfer case disc e-brake. I know some who have and it seems fine. Sometimes it takes a little connect/disconnect but it has proven useful when trying to reposition the front end for a better line in some more technical situations.
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #2 on: April 09, 2008, 06:29:38 PM »
i also got 1 but its not installed on the x-90 yet. Brent said it should hold up to my v-6 with a lite rig.  i hope he's right. it'll be cool to have front & rear disconnects.    stan
Offline whateverworks
  • 110
« Reply #3 on: April 09, 2008, 10:02:20 PM »
I installed a Trail Tough rear disco in my buddy's Sammi and it was a pretty easy install. Took about 20 minutes and also added the Toyota drive line adapter to it as well... Looks tough and is syncro'd as well... It will also connect and disconnect at low speeds pretty easily.
Kelly
  • 62
« Reply #4 on: April 09, 2008, 11:12:11 PM »
How does the disconnect mount?  Got any pics...Trail Tough didn't have much on their site just one picture that I couldn't tell much from.
  • 110
« Reply #5 on: April 10, 2008, 07:21:33 AM »
There are 3 bolt holes on the rear of the sammi transfer case and they bolt up to those. Very simple install.
Kelly
Offline cj
  • 1276
« Reply #6 on: April 10, 2008, 02:49:01 PM »
http://www.izook.com/tech/samurai/drivetrain/ttdsdisconnect/dsdisconnect.htm
My twinstick, t-case e-brake & disconnect arrived today too  :) Picked up the new case this week so now I can fit the 6.5 gears and these other parts and it should be  8)
  • 62
« Reply #7 on: April 11, 2008, 12:06:29 AM »
Thanks for the link CJ you must have read my mind as you answered all of the questions that were bouncing around in my head waiting for my new parts to arrive ;)
