Track/Kick 94 rear axle - how can i fit the RD74 ?
  • 1535 Views
Offline raanan
« on: June 12, 2005, 08:26:59 PM »
Hi all
I have 4 door 94 model tracker, and I have used RD74 (rear ARB locker for 89-92 Track/Kick).
I Know they can't fit together !( cause my crown have 12 bolts and my locker have 10 holes)
My questions is :
A. can I fit 91 model third member  to my 94 rear axle without any problem ?
B. can I only replace my crown (12 bolts) with older crown (10 bolt from track/kick 89-92 with the same dif' ratio)?
C. why Suzuki made this change ? , is for better handling with 16V engine power ?
Thanks for all answering
Raanan
Re: Track/Kick 94 rear axle - how can i fit the RD
« Reply #1 on: June 12, 2005, 10:56:51 PM »
A- Yes you can, it will bolt right in.
B-You can replace your 12 bolt carrier with an older 10 bolt carrier. I had to do just the opposite to fit my 5.83 gears in my 89.
C- they did it for a stronger set up.
HTH,
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #2 on: June 12, 2005, 11:49:19 PM »
You'll need to order a new Flange Cap #023301 and a new Differential Case #011904. These are the different parts between the 10 bolt RD74 and 12 bolt RD79 ARB lockers.
