lockers
  • 3391 Views
Offline Nicksidekickin
  • 104
lockers
« on: April 12, 2008, 08:21:48 AM »
hey guys,
  Will a lock right locker for a 89 thru 95 sidekick fit on a 96 sidekick
                                                             thanks
                                                               nick
1.5 coil spacers front and rear
custom rear bumper
windshield post lights
front push bar
electric fan
aftermarket exhuast
31x10.50s on 15x8s
1.5 body lift
Offline whateverworks
  • 110
Re: lockers
« Reply #1 on: April 12, 2008, 08:33:09 AM »
hey guys,
                                                             thanks
                                                               nick
Yep it will... Lock Rite 1512.
Kelly
  • 104
Re: lockers
« Reply #2 on: April 12, 2008, 08:35:49 AM »
Yep 1512 is it I think i'm fixin to get one
custom rear bumper
front push bar
electric fan
aftermarket exhuast
31x10.50s on 15x8s
1.5 body lift
Re: lockers
« Reply #3 on: April 12, 2008, 12:33:47 PM »
You mean for the rear right?  In the front they changed the splines from 22 to 26 in 1996, so if you order a locker with side gears you have to get it for the right year.
Offline Trackin_Tracker33
  • 137
  • Have Gun will travel
Re: lockers
« Reply #4 on: April 12, 2008, 09:23:21 PM »
how hard would it be  to put one of lockers in on a 96 track??  can anyone do it ??
I got your Jeep thang,  thats why it burns when I pee..
Mods: BDS 2" susp., Rocky Road +2'' Body, OME struts, flipped strut mount, custom High lift mount, CB, 30x9.50x15 RVT's
Comming soon.... To hell with IFS,  SAS'N it
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: lockers
« Reply #5 on: April 13, 2008, 01:34:05 AM »
Check out this page:
http://www.acksfaq.com/pdfs/Backlash.pdf
Of course, you have to pop the rear axles out in order to remove the third member.  The Samurai version of this process - which is very similar - is documented here:
http://www.zukikrawlers.com/showthread.php?t=2905
http://www.zuknation.net/zuknation/ZN/modules.php?name=Forums&file=viewtopic&t=616
or more specifically for the Tracker (minus the backyard mechanic tricks):
http://www.acksfaq.com/96-FSM-v1-4b_pdf.php
I hope that this helps!
Ack
  • 104
Re: lockers
« Reply #6 on: April 13, 2008, 06:38:40 AM »
Yeah for the rear i cant afford both at the moment.
custom rear bumper
front push bar
electric fan
aftermarket exhuast
31x10.50s on 15x8s
1.5 body lift
Re: lockers
« Reply #7 on: April 14, 2008, 04:02:40 PM »
I don't believe they ever made a locker with sidegears for anything other than the 26 spline rears, did they?  The 1512 comes with replacement 26 spline sidegears (you can use this in the rear of trackicks and samurais, or in the front of the 96 and up trackicks).  The 1510 doesn't, so you reuse your stock sidegears (no matter whether they are 22 or 26 spline....and you can run the 1510 in the front or rear of a trackick or samurai).
Re: lockers
« Reply #8 on: April 15, 2008, 01:49:29 PM »
I know the Detroit Ez-Locker can be ordered with 22 spline side gears from when I originally ordered mine years back, I assumed the Track-Lock would as well.  So no idea.  :)
