calmini vs rro
  • 4280 Views
Offline losidriver2003
  • 79
calmini vs rro
« on: April 12, 2008, 05:38:24 PM »
i have a 01 xl7 i haven't read about the rro 2 in susp. lift only there ad. iread lots about calminis .i was leaning towards the calmini. which one gives a smoother ride? i'm mostly on fire roads in the so cal mountians they can be bumpy at times
01 xl7 calmini susp rro body lift 225 75 16 tires
  • 79
Re: calmini vs rro
« Reply #1 on: April 18, 2008, 11:17:58 PM »
well i never heard anyone say if they have the rro susp lift .so i went with the calmini susp and rro body lift with geo 225 75 16  if i can figure out how to post a pic i will when its done.
Offline blacknight
  • 987
    • Gonzookin
Re: calmini vs rro
« Reply #2 on: April 19, 2008, 05:13:41 PM »
calmini was the way to go. once it breaks in the ride is good.  as for the 225/75/16's they might look small but that might be me . I'm running 245/75/16's with calmini and rr body lift
  • 79
Re: calmini vs rro
« Reply #3 on: April 20, 2008, 05:06:57 PM »
thanks for the reply blackknight.as for the tires its a automatic and the geo a/t is kind of heavy.this is my first mini truck. i havent seen any preformance mods for this eng. do they even make a comp chip for this?
  • 79
Re: calmini vs rro
« Reply #4 on: May 30, 2008, 08:42:52 PM »
blacknight, since you have the same lift with bigger tires. my front left tire rubs at full right turn on the calmini a arm. did you put spacers in the front wheels? the rest went pretty good. i wish they would have sent a brake line kit. i geuss ill have some made. im happy with the tire size 225 75 16  might change my mind when i hit the sand.and does anyone know if we will be seeing any rear end mods in the future even a limited slip would make me happy.        thanks for all the help Joe
  • 79
Re: calmini vs rro
« Reply #5 on: June 03, 2008, 06:24:37 PM »
"01"xl7calmini lift rro bodylift 225/75/16
Re: calmini vs rro
« Reply #6 on: September 10, 2008, 07:30:37 AM »
My likes dat!
