axle rotation ?
  • 14 Replies
  • 3310 Views
Offline donovanperro
  • 27
axle rotation ?
« on: April 13, 2008, 05:08:46 PM »
u rotate the axles to componsate for the body lift or sespention lift to make it eazyer on the u joints right??? when should u worrie about this after how big of a lift ?
Offline Amilla
  • 1076
Re: axle rotation ?
« Reply #1 on: April 13, 2008, 10:06:01 PM »
You dont have to rotate anything for a body lift, none of the drive components are moved when you do this.
When you start raising the transfer-case up you start to loose your pinion angle.
Most people will roll there axle back when  putting new spring perches on, so that they can correct there pinion angle or set it up for a CV drive shaft.
You cant really point the front axle up, because you will effect the way the steering works.  Unless you want to cut the knuckle balls off and weld them back up to how they should sit.
Are you planning on doing a lift of some sort?
Amilla
  • 27
Re: axle rotation ?
« Reply #2 on: April 19, 2008, 03:17:03 PM »
yes but im not goin over a 3" im probly looking at a 2"
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: axle rotation ?
« Reply #3 on: April 19, 2008, 07:22:14 PM »
What kind of lift on what kind of truck?
Derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
  • 27
Re: axle rotation ?
« Reply #4 on: April 20, 2008, 10:01:02 AM »
i hav a 91 asuna 5spd now. i  just finished a body swap from a 92 auto asuna sunrunner i like 5 spd better than auto so this is my next step im thinking of getting some spacers from jeff on here and goin with the mustang shocks and my strutt mounts are allready flipped im gunna get the combo of 2 /1.5" for the front
Offline derekj
  • 784
Re: axle rotation ?
« Reply #5 on: April 20, 2008, 09:31:45 PM »
You wont need to worry about driveline angles with only a 2" lift. I have been running one on my truck for 3 years now w/o any problems.
Derek
91 Sidekick jx
2" BDS body lift
1" Coil spacers
Offline aaron74
Re: axle rotation ?
« Reply #6 on: April 21, 2008, 12:05:58 AM »
Never mind the angles!  Isn't the axle rotation really about letting the rear articulate and moving the axle back an inch?
I used to be indecisive but now, I'm not so sure.
  • 27
Re: axle rotation ?
« Reply #7 on: May 01, 2008, 11:35:39 AM »
this make the rear articulate more ???? or
Offline aaron74
Re: axle rotation ?
« Reply #8 on: May 01, 2008, 09:52:54 PM »
My understanding was the rear articulated better because this helps relieve the angle that the top mount finds itself at after a lift.  Rotation also kicks the pinion up and reduces the angle of the bottom u-joint but I have thought the real benefit was the reduced binding.
Re: axle rotation ?
« Reply #9 on: May 02, 2008, 05:16:11 AM »
It actually moves the axle back more like 2", all the other stuff still applys.
Offline Uncivilized
  • 1469
    • Car Domain
Re: axle rotation ?
« Reply #10 on: May 02, 2008, 05:57:07 PM »
You won't get any more articulation unless you have full lenth springs and the F150 shocks.
Offline aaron74
Re: axle rotation ?
« Reply #11 on: May 02, 2008, 09:58:41 PM »
I understand the need for longer shocks but what about the springs?  I was just going to use a limiting strap to stop anything from falling out, reduce the binding of the top knuckle, and take the extra 2"!! of wheelbase.  I have 2" spacers right now but could be convinced to use XJ springs (cut down?).  Now that I am thinking about it, if the springs were anchored top and bottom, I would probably get more flex and only have to use the limiting strap to protect the shock.  I'll have to measure everything up first though.
Re: axle rotation ?
« Reply #12 on: May 02, 2008, 10:13:32 PM »
You might need a 3/4 or 1" drive line spacer also.
Re: axle rotation ?
« Reply #13 on: May 03, 2008, 01:31:10 PM »
You should never anchor both ends of the spring, over compressing or over extended a spring will soon kill it. That is why it always the shocks that limit the down travel (and why you have bump stops).
Offline aaron74
Re: axle rotation ?
« Reply #14 on: May 03, 2008, 02:41:42 PM »
fair enough ... then there is no need to run out and get XJ springs!
