front 3rd member swap???
donovanperro
27
April 13, 2008, 05:55:38 PM »
i was woundering if a 99 Suzuki grand Vitara 5 speed. The XL7 front 3rd member, will replace a 92 asunna sunnruners with any problems i heard of sombody doin this before because of its weakness being alun. any say or info on this thanks
thedon
Rhinoman
4502
36
Bend it, Break it, Fix it
Re: front 3rd member swap???
April 14, 2008, 04:47:28 AM »
Theres an article in the Technical section of the archives. The XL7 3rd can be used but you will have to fabricate a new mounting. The steel diff housing from some V6 and diesel GVs can be used and is a direct replacement. You will need to build your gears into the new housing to get the ratios right and to match your 22 spline driveshafts.
http://www.rhinopower.org
whateverworks
110
I Love ZUKIWORLD!
April 14, 2008, 07:09:07 AM »
You may as well find 26 spline cv shafts as they will be a bit stronger. Or go with the Toyota CV swap.
Or... You can sell that steel third member to me for my 'Kick
Kelly
