sidekick break can u modify have u done it
  • 15 Replies
  • 4655 Views
Offline wezzlegod
  • 227
  • under construction crowler
« on: April 15, 2008, 09:39:31 PM »
im puting toyota axles undre my sidekick and i have a qestion about the perportion valves in the break system. can thay be removed and the breaks tubed straight to the master silender. maybe someone that have done this modification or experemented wit the break system. what did you do to solve this problem. please help.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: sidekick break can u modify have u done it
« Reply #1 on: April 15, 2008, 10:27:16 PM »
I'm putting toyota axles under my sidekick and I have a question about the proportion valves in the brake system. Can they be removed and the brakes tubed straight to the master cylinder? Maybe someone that has done this modification or experimented with the brake system? What did you do to solve this problem? Please help.
Translated it for ya! ;)
Offline Carnage
  • 2453
« Reply #2 on: April 15, 2008, 10:32:42 PM »
Thanks Dig!
Offline sklope
  • 135
  • BUSHWACKER
« Reply #3 on: April 15, 2008, 11:37:38 PM »
Thanks Dig!
Yea, I want to thank you too Digger! I don't know if I could drink enough beer to figure that one out. ;D
* '96 Tracker
* 2" Sky body lift
* 235/75/15 M/T's
* Custom front and back bumpers
* Durabak exterior coating (bed liner) * '07 chevy silverado "wail tail" tailgate cover (custom cut to fit)
Offline gravity_storm
  • 108
  • The wino and I know
« Reply #4 on: April 16, 2008, 06:40:26 AM »
Thanks Dig!
Yep, brakes sometimes break but breaks don't have brakes.  ;)
1996 Sidekick, 1.5" homegrown body lift, 2" Digger suspension lift, home made snorkle, front skid
« Reply #5 on: April 16, 2008, 07:24:24 AM »
You guys are harsh.
I like it. :laugh:
Offline locjaw
  • 2045
  • 22
« Reply #6 on: April 16, 2008, 07:40:00 AM »
You guys are harsh.
I like it. :laugh:
well, DUH!!!
ROTFLMAO
and wezzle...... keep us posted on your findings and results please cuz i'm gooing to have to do that modification one of these days too.
Offline wezzlegod
  • 227
« Reply #7 on: April 16, 2008, 08:15:12 PM »
well i was hopping the guy that built rockstar would have somthing to say. or mike rpm if thats not the same person. i hate to go blind with no good feadback in to this mod. ??? ???
Offline sklope
  • 135
  • BUSHWACKER
« Reply #8 on: April 16, 2008, 08:33:53 PM »
To be honest, I would like to know if there is an alternative to the valve myself. I have sprung a leak on mine, nothing serious, and I really don't want to spend the $400+ price tag for a new one.
Sorry wesslegod, we just could not resist "jacking" with you a little! ;)
* '96 Tracker
* 2" Sky body lift
* 235/75/15 M/T's
Offline Digger
  • 1991
« Reply #9 on: April 16, 2008, 10:37:02 PM »
If I remember right, Heather came accross a similar issue with her 4door SAS Kick. Might be some topics about it around here...
Offline aaron74
« Reply #10 on: April 16, 2008, 11:14:15 PM »
Different applications, but I just eliminated all the stock proportioning valves on mix and match trucks and if the brakes were locking up too easy in the rear (tested on a gravel road with speed) then I added an aftermarket proportioning valve to dial it down.  You can't really predict these things that well when you are mixing different master cylinders with variable slave cylinders (especially after you have swapped out drums for rear discs.)  Remember that tire size can make a big difference too ... I found my Subby rear brakes locked up 38s a little too easy on the gravel (they were Ford dual piston 1 ton calipers) but were no problem with 44s.
The worst case scenario is that you can have a master that just does not move enough volume for large pistoned (or dual pistoned) calipers ... this has not really been my experience though.  And I am not sure that you will find big volume enough differences in the hardware between Zuks and Toys.
The factory proportioning valves (designed for a certain model master/slave combination and tire size) is unlikely to be the right thing for your new slaves and wheels.  I would recommend removing them and being prepared to buy a variable proportioning valve.  That said, you could always leave them in there and try it out as is (you haven't much to lose but a little time and the cost of blank fittings.)  You probably won't get a more detailed explanation than that because it really depends on your build (unless you are copying someone else's build.)
I used to be indecisive but now, I'm not so sure.
Offline wezzlegod
  • 227
« Reply #11 on: April 17, 2008, 12:32:35 PM »
ok thanks thats more of the reply i was looking for the thing i was most concered with was the frunt breaks because thay go into the frunt p valve and was woundering if it would mess with them if i eleminated the frunt one i was planing on getting a ajustable p valve for the rear if thay locked up to much on hard breaking. thanks for your info it helps.
Offline Carnage
  • 2453
« Reply #12 on: April 17, 2008, 12:41:00 PM »
ok thanks.  thats more of the reply i was looking for.  the thing i was most concerned with was the front brakes because they go into the front p valve.  i was wondering if it would mess with them if i eliminated the front one.  i was planing on getting an adjustable p valve for the rear if they locked up too much on hard braking.  thanks for your info.  it helps.
« Reply #13 on: April 17, 2008, 12:57:18 PM »
That's too much.
Must not laugh.  Have to resist.  Ahhhggg!  :laugh:
Offline JoeCool
  • 164
  • Carpe Noctum!
    • cardomain
« Reply #14 on: April 17, 2008, 07:38:51 PM »
Thing is, you need a proportioning valve. If you are running equal pressure to the front and rear brakes the rear will lock or the front won't be as effective as it should be. My bet is to buy an adjustable aftermarket unit. Every body running different from stock tires and ride height should. I'm being a little hypocritical as I am running a lift, larger rubber and bigger front calipers. But if you are running a significantly modified brake set up and use it for a much road use you should consider it.
~PS~ Firefox web browser will underline in red your spelling mistakes, and IE has a button.
5psi turbo '90 2dr 5spd 8v Tracker, Lt235s, 1" spacers, Rocker Rails, Warn Hubs, Custom half door,--GONE!
New, Sammi Tintop
