Engine starts but dies just as quick
  • 10 Replies
  • 3255 Views
Offline sepedaj
« on: April 21, 2008, 09:08:04 PM »
I recently purchased a 1988 sami, it is completely stock. The person I bought it from said it ran when parked and they let it sit for 2-3 years and had it running 3-4 months ago but it died and never started again. I put a battery on it and it turned over good, I found a fuel line missing; replaced it and it fired right up and ran very rough, which was expected. I then added some fresh gas and it fires right up but dies just as quick. If i look into the carb it looks dry. Some helpful hints will be appreciated
Offline idaholwb
  • 772
Re: Engine starts but dies just as quick
« Reply #1 on: April 21, 2008, 09:38:45 PM »
 Suzuki Samurais had a factory recall for something that might be your very problem. The catalytic convertor.
 There is a relatively simple test you can do to test this out. Unbolt your Exhaust pipe from the exhaust manifold and try starting it with the pipe not hooked to it. If it starts you know what the issue is.
 Your local Suzuki dealership can look up your vehicle recall information and see if you are a candidate for a free down pipe with cat. Many vehicles were covered. 86, 87, and part of 88 were all covered years.
 They will replace it free of charge, even if you aren't the original owner. I havce taken care of many through the local dealership here. Made many people happy that way.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline sepedaj
« Reply #2 on: April 22, 2008, 08:21:01 PM »
Thanks, I will check that out
« Reply #3 on: April 23, 2008, 01:08:36 PM »
Another thing to check is your fuel.  Mine acted similar when the fuel pump went out, and a plugged fuel filter will do the same thing.  Especially if it has been sitting for a few years.
Pull the fuel line off of the carb and have someone crank over the engine.  This way you can tell if your getting any fuel up to the carb.
Offline sepedaj
« Reply #4 on: April 23, 2008, 09:28:22 PM »
Yea I am getting fuel up to the carb and when I first turn it over it fires right up and will repond to the accelerator for a second or two and then it dies. I then wait 15-30 secs. and it does the same again. But if I try it immediately after it dies it won't fire back up. So how would a bad cat. converter cause it to die.
« Reply #5 on: April 23, 2008, 09:43:05 PM »
Sounds like your carb is plugged up.
Offline sepedaj
« Reply #6 on: April 26, 2008, 05:02:35 AM »
 THANKS.  I should get home at a decent hour this evening and will have a chance to check that out
Offline sepedaj
« Reply #7 on: May 01, 2008, 08:03:46 PM »
Ok, the carb just needed cleaning. Does anyone have any suggestions for a good high mileage oil or oil for older engine. the radiator also has a bad leak and will need replacing any ideas of where I can get a good radiator
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #8 on: May 02, 2008, 12:45:53 PM »
You're about to go on a very, very peculiar journey...
http://www.bobistheoilguy.com/forums/ubbthreads.php
XL-7 front coils
1.5" rear coil spacers
« Reply #9 on: May 02, 2008, 01:25:39 PM »
I wouldn't put any synthetics in.  They have a way of cleaning your engine when they go through, to the point that it gets rid of all of the old oil that was keeping your engine from leaking like a seave.  :D
Offline rascott
  • 669
  • 15
« Reply #10 on: May 02, 2008, 01:48:07 PM »
i don't use synthetic due to price.
lately i've been using 20W50 in my very worn 1.3L.
no leaks and no noticeable smoke, but i need to add some every couple of fillups.
richard
