o i got a tough one for u guys
  • 16 Replies
  • 4782 Views
Offline mahimahimo
  • 377
« on: October 12, 2004, 12:28:19 PM »
 alright heres the deal for sum reason whenever i make a sharp left hand turn my brake light goes on have no idea  y
                -thanx mo
Offline mahimahimo
  • 377
Re: o i got a tough one for u guys
« Reply #1 on: October 12, 2004, 12:28:54 PM »
o and it shuts off after the turn is done
Offline TomKat
  • 211
« Reply #2 on: October 12, 2004, 12:39:33 PM »
Brake master cylinder level low? take a look...
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline mahimahimo
  • 377
« Reply #3 on: October 12, 2004, 12:42:44 PM »
ill check but just to clarify things its the light that pops up when u pull the ebrake... and 90 % of hte tiems its only on left hand turns which is really confusen me  ??? ??? ???
                         -thanx mo
Offline TomKat
  • 211
« Reply #4 on: October 12, 2004, 12:50:52 PM »
                         -thanx mo
That is the same one that will illuminate when the master is low on fluid. As for the left turn, ......huh, wierd :-/
Offline mahimahimo
  • 377
« Reply #5 on: October 12, 2004, 12:54:58 PM »
lol freaken left turns.... ill deff check the master cylinder fluid
                       -thanx mo
Offline explosivo
  • 3157
« Reply #6 on: October 12, 2004, 01:30:24 PM »
Make sure your wheel bearings are tight/not shot. My brake light started coming on while turning/braking when my bearings were going out.
omghi2.us[/url]
Offline kansascitytracker
  • 335
  • 92 Tracker
« Reply #7 on: October 12, 2004, 01:43:09 PM »
At least you're not a NASCAR driver, 3 hours of left turns would make you really frustrated.
« Reply #8 on: October 12, 2004, 05:13:08 PM »
Hey three lefts make a right!
Offline tonka-toy
  • 154
  • tonka
    • tonka-toy
« Reply #9 on: October 12, 2004, 08:21:49 PM »
are you losing fluid from the master cylinder as i had the same thing. turned out it was low on fluid as the o ring oil seal on the master cylinder into the brake assister (servo) was naff and the fluid was being sucked into the brake servo (assister )sp.
i removed the fluid from the inside of the drum and a couple of months later this packed up as well ..... aaaaaaagghhhhhhh :-/
anyway .. it was turning that caused the fluid in the master cylinder to move and trip the sensor
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #10 on: October 13, 2004, 02:27:53 AM »
I had the same thing happen, but with both left and right turns. It was because my brake fluid was low. I was leaking out of a rear wheel cylinder.
Heather
« Last Edit: October 13, 2004, 02:28:07 AM by hcgalvin »
Heather Galvin
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #11 on: October 13, 2004, 05:23:15 AM »
My tarcker did that...I just drove it :P. But most likely it's the master brk cilnder.
Offline LawDog
  • 531
    • Emerling Chevrolet
« Reply #12 on: October 13, 2004, 10:33:05 AM »
Hmm...I just put new bearings in and mine lights on.  Must mean I did it right, like a gold star or something. ::)
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #13 on: October 13, 2004, 10:34:09 AM »
Mine has a leaky cilinder in the rear too, but not too bad, yet.... But when it has leaked enough fluid that light will come on when turning because the sensor will be think there's not enough fluid left. With mine it also starts in left turns and if it has leaked enough it will also do it on right turns.
So your brake fluid level is low. Could be a cilinder leaking or something like it.
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline mahimahimo
  • 377
« Reply #14 on: October 13, 2004, 11:32:43 AM »
just filled it and gonna go out for a drive it was a little low but not to bad
