Big Tires = Big Problems?
  • 9 Replies
  • 2836 Views
Offline 79mic79
  • 22
« on: April 25, 2008, 09:12:46 AM »
Hey Guys, quick question:
I installed 1" coil spacers from Rocky Road Oufitters last August on my 2001 GV Ltd 95,000kms. , and even though it wasn't much of a lift my drive shafts were making a lot of banging noise due to the angle change, had to have them rebuilt. In November '07 I put on 245/70/16 BFG A/T tires, trimmed/cut the front wheel covers so they don't rub, they look great and the ride it still pretty smooth.
Here's the problem, it's only been 5 months (and I don't drive a lot) and now when i'm driving approx 40km/h on a highway ramp etc and turning the wheel slightly to the right i'm hearing a humming noise from the driver's friont tire, I can almost feel it through the floor. The same symptom happened to me with my old sidekick and it was the wheel bearing....
I was just wondering if everyone with bigger lifts/tires have experienced wheel bearing wear out, power steering wear out, transmission etc. so I can plan on what to expect with extra wear and tear?
Thanks
2001 Grand Vitara Limited 2.5, Beige
1" Coil Spacers, 245/70/R16 BFG A/T tires
Original Suzuki accessories: Front guard,chrome step bars,rear spoiler,window visors, chrome door locks,chrome tail pipe.
Aftermarket: Kenwood DVD/Navigation sys, Alpine 10" Sub,Alpine type S speakers,Kenwood 300W amp
Offline Armour
  • 360
Re: Big Tires = Big Problems?
« Reply #1 on: April 25, 2008, 04:29:36 PM »
You can expect some extra wear and tear on some things. Wheel bearings, tire size won't necessarily effect wheel bearings but wheel off set will. The wider the stance the harder it is on those. The tire you are running are not that big so i don't know if you willl have any probs with trans. But gears will compensate. I have 33X12.50 on my tracker. Have had no probs with wheel bearings yet but i have put a trans in it. But it an auto and I had a leak that i never realized till it was tooo late.
Offline l-0967
  • 14
« Reply #2 on: April 25, 2008, 05:43:11 PM »
Hello i put front hub lock on my 2002 tracker last fall ,and when i removed the cap i saw the balls of the weel bearing there was almost no grease on the bearing ,so i use a needle with bearing grease and i fill it and i never heard of it after. ???
It looks like a problem on those truck (bearing ) but if there no grease !!!
Hope you are not too late to put grease on
Bye
Bye
Marc
Offline JayInBarrie
  • 107
« Reply #3 on: April 25, 2008, 05:53:42 PM »
I put in the same spacers last year as well, in my '99 2 door tracker.  No drive shaft, CV, or bearing issues.  My driving habits are similiar to, I'm just at 103,000 km.
The only big issue I have is the front diff.  You can check out the other posting on the Shift-On-The-Fly stuff.
Good Luck ???
99 2dr Tracker, 33" tires stuffed in, home made roof rack.
Offline 79mic79
  • 22
« Reply #4 on: April 28, 2008, 11:36:34 AM »
Thanks guys, i'm going to have it checked out and i'll let you know what ends up being the problem.
Offline Armour
  • 360
« Reply #5 on: April 28, 2008, 04:05:34 PM »
Almost guaranteed that noise is wheel bearing!
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #6 on: April 28, 2008, 07:47:34 PM »
Sounds like wheel bearing is done or lack of grease or preload is off.
01 GRAND VITARA
Offline Armour
  • 360
« Reply #7 on: April 28, 2008, 08:29:41 PM »
Regardless. If it is making noise i wouldn't hesitate to change it. Its not going to get any better.
Offline bzzr2
  • 1011
« Reply #8 on: April 29, 2008, 06:30:02 AM »
i've replaced the passenger side wheel bearing at around 50,000km.
09 taco reg cab short box 4x4
Offline 79mic79
  • 22
« Reply #9 on: May 20, 2008, 11:37:16 AM »
Ok so I had the truck up on the hoist this weekend, and the weird thing is after letting the front wheels spin (in 4x4) the passenger bearing was a bit noisy, the driver side wasn't, and there was no play in either wheels.
So I ordered an aftermarket hub/wheel bearing and replaced the passenger side....the truck now turns a bit easier but the noise is still heard/felt at about 40kms/hr. Either I changed the wrong side (believe me I thought for sure it was the driver's side, but if there is no noise or play but the passenger side was noisey then I changed the passenger side instead) or the noise is something else...poor tire balancing, BFG A/T tire making the noise at lower speeds (does anyone find this?) or something in the CV shaft.
Either way I know the noise isn't totally gone, but at least I know that there are no loose/dangerous front end components that I have to worry about falling off while I drive...for now. I might change the driver's bearing later this year anyways just in case it is the culprit, plus the old one taken off the passenger side was so rusty it might be a good idea just to change it.
Thanks for everyone's help.
