Valve seal WTF?
  • 18 Replies
  • 6069 Views
Offline pepatt
  • 174
Valve seal WTF?
« on: April 25, 2008, 06:37:14 PM »
OK, when it comes to leaking valve seals, I completely understand a puff of smoke upon start up. I can understand oil seeping through the seals and running down the valve guides into the cylinder when the engine is at rest and being burned off at startup. That all makes sense.
But another classic symptom of bad valve seals is a puff of smoke after idling for a while.
So here is the $64 question:
How does oil get down through the valve guides with the cylinders under compression?
I have tried and tried to wrap my mind around this. Am I missing something?  ???
I know somebody has the answer.
C'mon, out with it!
pepatt
Re: Valve seal WTF?
« Reply #1 on: April 25, 2008, 07:15:03 PM »
Well the compression is in the cylinder, The valve guide seal is in the vacuume
of the intake system. oil gets sucked down with the intake of gas and air.
BUT idle and loading up with oil is more likley bad rings, now don't you wish
you just left this question alone ???
Offline pepatt
  • 174
Re: Valve seal WTF?
« Reply #2 on: April 26, 2008, 05:17:18 PM »
now don't you wish you just left this question alone ???
If I had bad rings, I indeed would wish I hadn't asked. However, my compression test tells me it's seals.
So now what's the answer?  ???
pepatt
Offline Uncivilized
  • 1469
    • Car Domain
Re: Valve seal WTF?
« Reply #3 on: April 26, 2008, 06:26:24 PM »
I did my seals a couple weeks ago. Yup, need to pull the head again... the rings now show their old age. This happened to me before, and I said I'd never do another head job without replacing the rings. It was smoking really bad with the 5W30 oil until it would warm up a bit, so I put in 15W40 and it's not so bad now, so I'm going to wait until the fall and I'm going to rebuild the bottom end, at least the head is done  :P
Re: Valve seal WTF?
« Reply #4 on: April 29, 2008, 08:39:26 PM »
All your compression test is telling you is that you have a good compression ring, what about the oil control ring and the scraper?
Offline pepatt
  • 174
Re: Valve seal WTF?
« Reply #5 on: April 30, 2008, 10:15:16 AM »
Look, if the compression rings are good and compression is good and stable, then there should be no blow-by and therefore rings are a non-issue. I have rebuilt several motors and done a lot of top ends on dirtbikes and quads. I'm not a newbie to the whole diagnostic scene.
My original question wasn't if I need new valve seals - I have determined that my engine does, in fact need new valve seals - my question was why an engine with bad valve seals will smoke (upon acceleration) after idling for a period of time.
I've had more than one vehicle do this and valve seals did in fact fix the problem.
So while I appreciate the helpful spirit, I'm really looking for a physics lesson.  :)
« Last Edit: April 30, 2008, 10:16:48 AM by pepatt »
pepatt
Re: Valve seal WTF?
« Reply #6 on: April 30, 2008, 10:33:07 AM »
Oil that leaked by the seals will soak into your carbon deposits and will not burn off untill you get it hot enough to do so.
Re: Valve seal WTF?
« Reply #7 on: April 30, 2008, 10:37:33 AM »
Where did ya go I see your online?
Re: Valve seal WTF?
« Reply #8 on: April 30, 2008, 10:41:29 AM »
Ok food for thought time, ok where are places that carbon could build up? I will start with the piston top, what does your egr valve do and when does it work?   your turn!
Offline pepatt
  • 174
Re: Valve seal WTF?
« Reply #9 on: April 30, 2008, 05:55:21 PM »
Hmmm. Interesting. Hadn't thought of that. Makes sense. I have seen carbon buildup in small engines that was very oily - even under high rpm conditions. Guess it could soak in there and burn off slowly. I would think that it would gather around the valve ports before the piston top, but yeah, I'll buy that.
Here is a theory of mine - see if it makes any sense:
When the engine is at idle, the seals are relaxed and allow oil to bypass. The oil sits in the valve guides. Upon acceleration, vacuum builds as air/gases flow in/out of the valves. This vacuum pulls the oil out of the valve guides and into the combustion chamber and exhaust port where it is burned off. At the same time, the vacuum also pulls on the valve seals, effectively resealing them (why you don't get smoke under load) until the next time the engine is at rest or at low rpm (idle).
It's just a theory. I like to think and hypothesize about this junk. :P
« Last Edit: April 30, 2008, 05:57:19 PM by pepatt »
pepatt
Offline RHodge
  • 523
Re: Valve seal WTF?
« Reply #10 on: April 30, 2008, 07:32:55 PM »
Have you ever put a vacuum gage on an intake ?  the motor makes vacuum at idle, as the rpm's come up the vacuum drops witch is why you don't get smoke under load(if you only have bad valve seals).  I think you may want to check out the valve guides too
Ryan
Re: Valve seal WTF?
« Reply #11 on: May 01, 2008, 07:40:25 PM »
I was playing devils advocate on the second post, but Mr Fuelish hit the answer
oil builds up and burns off when cyl temps rise.
Offline pepatt
  • 174
Re: Valve seal WTF?
« Reply #12 on: May 03, 2008, 04:38:09 PM »
Suuuurrrrre! ::)
OK, so why don't bad valve seals smoke all the time ie: highway driving?  ???
There has got to be a reason oil stops flowing down the valve stems/guides during normal operation.
pepatt
Offline RHodge
  • 523
Re: Valve seal WTF?
« Reply #13 on: May 03, 2008, 07:32:12 PM »
Suuuurrrrre! ::)
no oil build up/ the acclimated oil gets burnt off when you start the rig after it's runing there nothing to burn
Offline pepatt
  • 174
Re: Valve seal WTF?
« Reply #14 on: May 03, 2008, 08:16:22 PM »
But oil does build up at idle. What gives there?  ??? ??? ???
I guess it's not important -  I just wondered.
The valve seals are fixed. No more smoke.
It seems the question keeps getting re-hashed.  >:(
pepatt
