diesel conversion info needed
  • 11 Replies
  • 3672 Views
Offline serioushorsepower
  • 105
« on: April 27, 2008, 04:01:23 AM »
does antone have a picture of the adapter plate used to put the 1.9l vw diesel engine that goes in between the engine and automatic transmission (4x4)?? I have everything else to convert my toy but this plate. and they want an arm and half my leg just for the plate. I figure I could make my own with the plasma cutter and drill press. If anyone has a pic of it please let me know. thanks, Serious.
Nothing but power, Serioushorsepower!!
Offline ARISJ410
  • 16
Re: diesel conversion info needed
« Reply #1 on: April 28, 2008, 08:13:35 PM »
I am also considering doing the VW swap in the summer, but i need to find a good engine first... How much did you get yours for? and where ... a pull it yourself yard?
I found this picture
Its not from Acme but its from ROADLESS gear....
I unfortunately dont have a plasma cutter or the experience with a lathe, so i will probably go with the ACME because you get everything for the switch. and more wiring.
  • 105
« Reply #2 on: April 29, 2008, 03:51:21 AM »
I found a whole vw jetta for $500 here in ohio. Thanks for the info and good luck!!!
« Reply #3 on: April 29, 2008, 04:30:42 AM »
     arisj410 is that a video on the picture about how to convert sami to diesel, if it is where can i get one.
   thanks.
  • 105
« Reply #4 on: April 29, 2008, 04:41:04 AM »
I need the adapter for the tracker to vw. acmeadapters.com has the sammi one and the tracker.
« Reply #5 on: May 05, 2008, 12:06:11 PM »
is there a diesel swap that would work in a 1995 Sidekick 4 door 4x4 ?
Offline kingzoo
  • 461
  • I LOVE MY JLX SIDEKICK
« Reply #6 on: May 05, 2008, 05:01:30 PM »
   The vw swap will work,and euro import says they have the factory diesels from the euro model zuki that include electronics but not wiring,for $900 and up.
KING ZOO!!
« Reply #7 on: May 06, 2008, 04:51:13 AM »
Both Mazda 2ltr TD and Peugeot 1.9TD were OE installations outside the US.
Offline Carnage
  • 2453
« Reply #8 on: May 06, 2008, 09:11:52 AM »
acmeadapters.com
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #9 on: May 06, 2008, 10:56:51 AM »
I'm not positive I'd buy from someone who's still using VHS...
XL-7 front coils
1.5" rear coil spacers
Offline Carnage
  • 2453
« Reply #10 on: May 06, 2008, 04:00:40 PM »
gotta use those old tapes somehow
  • 105
« Reply #11 on: May 06, 2008, 04:31:32 PM »
The conversion kit through acmeadapters will work on all trackers up to 98 I believe. I think thats wjat one of there sales reps told me. I was just trying to find someone who makes the adapters to get it a tad bit cheaper that what eveyone else is wanting. Thanks,Serious.
