zuktoy axles under truck
  • 2350 Views
Offline wezzlegod
  • 227
  • under construction crowler
« on: April 27, 2008, 08:32:17 PM »
okay the truck sits on its wheels.I've got the axles installed and it's a roller for now.  I only have to run the new fuel lines and brake lines and measures for the drive shafts and put it on the forklift and measure for the shocks.  I have taken some pictures of the suspension to show you my installation.  I have made several posts of this project over the last two years.  If you haven't read them.  You might want to.  Just do a search of zuktoy.this is bad on ongoing project, and it's finally all most done.  In some of my last posts, someone said I would have problems with the steering.  If you look at the pictures.  You will see how I solved the problem instead of a one-piece steering system I've use, a two-piece, so the steering rod, mimics the upper track bar.here are the pics
« Last Edit: April 27, 2008, 08:52:58 PM by wezzlegod »
Offline wezzlegod
  • 227
Re: zuktoy axles under truck
« Reply #1 on: April 27, 2008, 08:36:03 PM »
pics
Offline RACER X
  • 383
  • zuki or die!
« Reply #2 on: April 27, 2008, 09:24:53 PM »
LOOKN GOOOOOD!!!!!!!!!!!!!!
98 kick
Offline Element
  • 1902
  • LillyKicker
« Reply #3 on: April 27, 2008, 09:51:11 PM »
Any of the front???
zUkTAH
U4WDA
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #4 on: April 28, 2008, 06:51:02 AM »
I'd love to see better pics of the front also. What is the purpose of 2 piece steering?
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline RHodge
  • 523
« Reply #5 on: April 28, 2008, 09:42:01 PM »
I'm going to guess that with the short track bar it maybe to help out with bump steer or steering loss at full turn. keep up the good work
