trim down strut extender
  • 1889 Views
Offline dentedzuk
  • 171
« on: April 29, 2008, 06:26:43 PM »
Hey all!
quick question has anyone else needed to or tried to trim down their boondox strut extender? I have a set i decided to go ahead and use and when i went to install them on some new Gabriel struts i discovered they wouldnt fully seat on the strut.. i got a buddy trimming them down to fit and also making a sleeve to double up and reenforce the extender but i was wondering if anyone else had that problem or did i just get lame struts!?
thanks
james
2001 2.0L 4dr Vit: Calmini 2.5" susp, 215/65R16's, Surco safari rack, cone filter, turbo muffler!
***FOR SALE***
2" R.R.O. B/L w/ steer extension - $125
Trackkick axle, $50
stock Vit springs - $50
2x 225/75R16s A/Ts(95% tread) -$85
pics- http://www.zukiworld.com/forum/index.php?topic=24765
Offline bzzr2
  • 1011
Re: trim down strut extender
« Reply #1 on: April 30, 2008, 06:39:24 AM »
my extensions were a bi7ch to put on, used heat on the extender to expand a little and presto, on they went, problem is now i'm going to be looking to get new struts, the extensions will never come off...
09 taco reg cab short box 4x4
Offline dentedzuk
  • 171
« Reply #2 on: April 30, 2008, 08:58:10 AM »
yeah they defiantly don't seem reusable.. i wish someone made a strut spacer in the states like bits4vits, his seem perfect for a spring spacer lift on the 2nd gens
***FOR SALE***
Trackkick axle, $50
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #3 on: April 30, 2008, 11:02:53 AM »
I bought a couple sets of strut extenders from Boondox (in Michigan).  Went to screw them onto my Gabriel struts and had the same problem too.  My heart sunk.  I thought all that work and now I'd have to reassemble to stock and think of something else.
However... what ended up working for me was an air dremmel with a course scuff pad mounted on it.  Hang on to the strut tightly and move it around the top of the strut shaft just below the threads and buff the shaft down.  You might want to run a nut down to the bottom of the threads to protect them, although the extenders don't screw downall the way.  After a few minutes of buffing while rotating the strut shaft trial fit the extender for clearance.  After you gain the needed clearance, coat the shaft with a light coat of grease (to prevent rust bond) and tighten.  Be careful cause the shaft will be more than warm to the touch!  The air dremmel removes just a little material at a time.  In fact, it "buffs" the metal off.  Within five minutes, you should be able to buff off the clearance obstruction.  You could also buff off the inside of the extender, but my thought was you would be removing metal from a fairly thin wall anyway, so i took it off the shaft.
BLUF:  The extenders need engineered with more inside diamater clearance.  I'm talking X amount of thousandth of more diameter.
Offline dentedzuk
  • 171
« Reply #4 on: May 03, 2008, 07:19:08 AM »
thanks for the advise nprecon. Im going to lightly buff the inside down a little to smooth it out. Hopefully to avoid the thin walls a friend was suppose to make a stain less steel sleeve and press over the walls to reinforce them a bit.  Havent talk to him on the status though he was doing it with free time at his shop so we will see!
***FOR SALE***
Trackkick axle, $50
