Gas mileage question
  • 33 Replies
  • 8466 Views
Offline Dazookster
  • 61
« on: May 07, 2008, 02:17:58 PM »
So I used to get 280 miles on a tank and then one day when i filled up it had dropped to only 180 a tank I have looked in to all sorts of thing that could affect it but it burns clean it passed emissions with getting that kind of milage and looking at the results the hc's are normal any ideas?
Wahoo for Global Warming more time to go Wheeling
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: Gas mileage question
« Reply #1 on: May 07, 2008, 02:24:52 PM »
To my mind, that much of a change can only mean fuel leak.  Start with the hoses under the hood.
First turn on the ignition to power up the fuel pump -- without actually starting the engine -- and feel/smell around for anything seeping from pipe-to-hose connections.  If nothing, try again after starting.  If still nothing, try again immediately after turning off the engine.
All of that, of course, is assuming you're actually putting a full tank's worth of gas in.  You'll get a lot fewer miles out of a dented tank, too...
XL-7 front coils
1.5" rear coil spacers
Offline Dazookster
  • 61
« Reply #2 on: May 07, 2008, 03:14:38 PM »
No I have checked for leaks fuel pump gas lines. Checked while running too its been a mystery to me for the past few months.
Offline RACER X
  • 383
  • zuki or die!
« Reply #3 on: May 07, 2008, 03:55:05 PM »
What changed.............. tires, gears, any thing, new plugs(1s not firing)somthing had to change along with your gas mpg or you need to catch the guy syphoning your gas and take his wallet then kick his ass !!!!!!!!!!!!!!!!!
98 kick
« Reply #4 on: May 07, 2008, 05:40:35 PM »
It's the new gas, try adding 2 bucks worth of Diesel to it per ten gallons of gas it seams to help mine out a little, the more they mess with the fuel the worse it gets, try sticking with mobile or chevron gas, I just took a two thousand mile trip and the cheap gas stations turned out to be not so cheap, I started out with 43 mpg and went down as low as 28 mpg with the same rig, same day of driving, same hwy, just diffrent gas stations.
Offline jzap
  • 515
  • How difficult can it be?
« Reply #5 on: May 07, 2008, 07:41:08 PM »
Also, check your tire pressure.
I have problems with the helpful people at the oil change places setting my tire pressure to the "factory recommended specification" of 23 psi.  Gas mileage drops to about 22mpg.  pump the tires up to about 35 psi, and I get about 29mpg.  Rides like a brick, but worth it...
Jim Z.
66 Apache camper
Offline pepatt
  • 174
« Reply #6 on: May 07, 2008, 08:14:05 PM »
It's the new gas,
This is most likely the problem.  Ethanol kills mileage. I had a Saturn that routinely got 300 miles per tank. One day, I decided to "save money" and I filled up with the "cheaper" 10% ethanol gas. I got 200 miles out of that tank. Out of curiosity, I switched back and forth to test my findings. It was no fluke. Since then I've stuck to 100% pure gasoline.
I keep mine at 30 psi for the same reason, my TracKick rides like a brick, yours must be more like a cement block  ;D
« Last Edit: May 07, 2008, 08:16:22 PM by pepatt »
pepatt
Offline Dazookster
  • 61
« Reply #7 on: May 08, 2008, 10:29:24 AM »
That has been pretty much the same response that i have gotten everywhere else that i have asked its the ethanol in the gas.  Are there any certain gas stations that don't put ethanol in there gas?  I have heard about the diesel gas but i was afraid that it would ruin my engine?
« Reply #8 on: May 17, 2008, 08:20:17 PM »
You can run a good amount of Diesel fuel mixed with gas it won't hurt anything most of the new Diesels run a cat and the new Diesel is ultra low sulfer.
« Reply #9 on: May 18, 2008, 07:37:33 AM »
Depends where you are.  In MO, after the first of the year, they made it manditory that all gas contain at least 10% ethanol......but they didn't seem to lower the price per gallon any to offset the worse gas mileage you get with the 10% blend.
BTW, I hate 10%.....I tried it years ago (when it was actually cheaper than the regular gas) and it always made the vehicle I put it in run worse and mileage seemed to go down too.
Recently, I have lost about 4-5 MPG, and I am still researching whether it is in connection with the 10% blend or something else that has affected it.
Offline Carnage
  • 2453
« Reply #10 on: May 18, 2008, 01:41:47 PM »
are you serious?   :-\
can anyone explain?   ???
« Reply #11 on: May 18, 2008, 02:15:08 PM »
Diesel is less refined than gasoline so it does not have near as many chemicals in it as gas, When you make gas from crude oil it kinda goes like kerosene, jet fuel, diesel, premium gas ,regular gas, and lpg was a by product of making gas that used to be just let out into the atomosphere and like k1 was just dumped some times I have heard early on, maybe some one on here knows more about it.
Offline Carnage
  • 2453
« Reply #12 on: May 18, 2008, 02:16:21 PM »
but youve put it in your tracker?
any damage/pings, etc
« Reply #13 on: May 18, 2008, 02:20:53 PM »
I have run it in my sammie for years, It has the 16 valve in it and it likes it, there is injector cleaner and what not in it also, go buy a bottle of injector cleaner and smell it, let me know what it smells like!
Offline Trackin_Tracker33
  • 137
  • Have Gun will travel
« Reply #14 on: May 18, 2008, 02:47:13 PM »
 :laugh:     BLLLAAAAAHAHAHAHAHAHAAA   Thanks for the great laugh...
Gen-Erix     just leave it alone       there is not point in arguing   I know it was hard for me not to say anything
I got your Jeep thang,  thats why it burns when I pee..
Mods: BDS 2" susp., Rocky Road +2'' Body, OME struts, flipped strut mount, custom High lift mount, CB, 30x9.50x15 RVT's
Comming soon.... To hell with IFS,  SAS'N it
