? about waterproofing breathers
  • 11 Replies
  • 3143 Views
Offline dres0081
  • 73
« on: May 07, 2008, 08:02:38 PM »
so i wanted to know what everyone is doing for waterproofing the breathers on the front and rear ends as well as the t-case and tranny. Does everyone just run rubber hose to a high point in the vehicle or is there some sort of one way valve you can use to to further protect from milky lube? I have heard that there is some sort of valve that they use on 4wheelers that might work
need advice bad ??? ??? ???
thanks
88 1/2 sami,yj springs spoa, 33s
Offline Cuthulu
  • 384
Re: ? about waterproofing breathers
« Reply #1 on: May 07, 2008, 09:13:17 PM »
I would ike to know abut this as well.   A buddy of mine has a Land Crusier and it just has a one way breather valve on his diffs.  I would like to go the same route, any ideas if it would hurt the diffs if you hit cold water fast and they could not breath?
Offline kingzoo
  • 461
  • I LOVE MY JLX SIDEKICK
« Reply #2 on: May 07, 2008, 09:22:27 PM »
   Most people just run the breather tube up as high as possible.I have done this many times with no problem.
KING ZOO!!
phloop
« Reply #3 on: May 07, 2008, 09:38:00 PM »
There are one way valves but they do not work as well as running the breathers together to a high point.
Offline Amilla
  • 1076
« Reply #4 on: May 07, 2008, 10:46:09 PM »
You can do this very cheaply, you just have to get some breather nipples.  You can get them off of nissan hard bodys and some other rigs.  Just pull out your old breather and screw in the new one and run a line up high.
Amilla
Offline dres0081
  • 73
« Reply #5 on: May 08, 2008, 05:33:53 AM »
hey Amilla i know i have been tapping you for knowledge all week but do you know which vehicles in particular have the breather nipples you are talking about. And whats a Nissan hardbody?
Offline pepatt
  • 174
« Reply #6 on: May 08, 2008, 05:47:24 AM »
... I have heard that there is some sort of valve that they use on 4wheelers that might work
Yes, they do use these on dirtbikes and atv's.
They're not what I'd call cheap. the one I'm posting is from the parts list (#13) from my bike and retails for $29.83!
It's just a rubber fitting at the end of the tube with a slit in it. They seem to work, but hell, it's cheaper to change the oil!
« Last Edit: May 08, 2008, 05:49:00 AM by pepatt »
pepatt
Offline Amilla
  • 1076
« Reply #7 on: May 08, 2008, 10:39:15 AM »
dres here are some pics of what you want to be looking for.  If you go to a junkyard just start looking under Isuzu's, Nissan's, and Toyota's.  Just look for hoses coming out of the top of the axles and heading up into the body.
They fit in your pocket so nicely too! ;)
4x4 nissan hardbodys are nissans 80s pick up.  IFS front, and a funny looking body.
Amilla
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #8 on: May 08, 2008, 10:50:09 AM »
I just ran mine up high, and then looped them back down about 6 inches.  Kinda like a reversed water trap.
Never had a water problem and I've been through 3-4 feet of water/mud before.
32 MTR's Warn 8000i
Offline dres0081
  • 73
« Reply #9 on: May 08, 2008, 06:18:09 PM »
thanks Amilla now atleast i know what to look for. worse case i can just run hose to a high point
Offline Cuthulu
  • 384
« Reply #10 on: May 08, 2008, 08:00:40 PM »
[/qu
ote]
Now that is a good idea!
Offline gravity_powered
  • 43
« Reply #11 on: May 09, 2008, 12:06:54 AM »
You could also plumb them into your air filter box.
If you ever manage to get water into them there milky diff oil will be the least of your problems.
'98 2.5 V6 Grand Vitara
TJM Bullbar
Lightforce 170 driving lights
Wombat Racks roof rack
235/70/16 Toyo Open Country A/T
