Looking for a cheeper alt for this.
  • 2713 Views
Offline Cuthulu
  • 384
« on: May 07, 2008, 09:16:51 PM »
http://offroadrecovery.zoovy.com/product/G81/CONFERR_BLITZ_JERRY_CAN_CARRIER_ADAPTOR.html
Really I would pay the case but then I would still need to buy the Gerry can holder and the one for this on the site is another 65 bucks.  I really like the idea just not the total price of 110$.  Links would be appreciated.
Offline kingzoo
  • 461
  • I LOVE MY JLX SIDEKICK
Re: Looking for a cheeper alt for this.
« Reply #1 on: May 07, 2008, 09:21:17 PM »
   I have built several from extra material laying around the shop.I have used plate from 8th inch to .25 inch,depending on what was laying around,and .25  inch box in 2 inch or 1.5 inch  cause we use a lot of that stuff and allways have some.
  If you can weld or have a buddy who can,the whole deal for the bracket should be under 40 bucks.
KING ZOO!!
Offline rascott
  • 669
  • 15
« Reply #2 on: May 07, 2008, 10:06:21 PM »
i'm almost embarrassed to mention this, but the request was for a cheaper alternative.......
3/4" plywood, cut in a circle just bigger than the rim.
jerry can bracket bolted offcenter(on what will be bottom), then bolts thru circle and wheel lug holes(2 worked for me), tightened up against tire.
i did this for many years with my montero and it worked great.
i did this again when i first got suzi, but was not comfortable with the extra weight when i started up-sizing my tires. became concerned about all that extra weight(8.337 lbs/gal.) on that little tailgate.
plus it stuck out farther than i liked(smaller vehicle).
i've mounted it just inside the back on filler side on some stowage contraption i've built.
i can fill it and siphon by just unzipping the window a little.
wish i had some pictures, 'cause i know it sounds hokey, but it really worked well(on my montero) and if i hadn't built the stowage thing, i'd probably still run it.
btw- no bad gas smell having it inside- even when it's sloshing on trails.
i wonder if i should post this?
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #3 on: May 08, 2008, 05:06:29 AM »
I'm enjoying this new trend in wood-fabbed-accessories posts.
XL-7 front coils
1.5" rear coil spacers
Offline Cuthulu
  • 384
« Reply #4 on: May 08, 2008, 07:40:56 AM »
I would love to see pics please.  That is not a bad idea, I am thinking about giving it a try with Marine plyboard.  I found the same mount system that I posted earlier at 4wheelparts and it is about 20 bucks cheeper over all.  I may go that route, however I thik I may try your idea first rascott.  It also seems like a good idea, I suspect that how it turns out will depend alot on my ability to cut a round hole.
Oh as for the weight on that tire rack.  I had the same concern, so one day why I was at the local Pick and Pull I climbed on top of the spare tire mount (since it wasn't mine) and bounced.  Soild as a rock and really I was expecting to take a dive. BTW I weigh a touch over 400 pounds so I'm thinking that I am good with a bigger tire and Gerry can.  ;D
   This was on a Tracker.
Offline rascott
  • 669
  • 15
« Reply #5 on: May 08, 2008, 09:14:17 AM »
i'm glad you didn't shoot it down right off the bat- like i said, i hesitated to mention it.
i'll look thru some of my old photos to see if it shows.
i made the circle just over rim diameter so that it snubbed against the tire, and it did work well and certainly was cheap to make.
i was worried |removethispart|@ extra weight on the hinges, but mabe i worry too much.
one of these days i'll have to post pics. of my current setup....
richard
