Sparkplugs + Oil?
  • 2160 Views
Offline Carnage
  • 2453
Sparkplugs + Oil?
« on: May 07, 2008, 10:02:16 PM »
Pulled a plug off the top of one of the sparkplugs and theres oil in there?
Its running fine but what does that mean?
Offline aaron74
Re: Sparkplugs + Oil?
« Reply #1 on: May 07, 2008, 11:55:18 PM »
leaky rocker cover gasket? check you valve lash recently? ... if not, might be time to do so.
I used to be indecisive but now, I'm not so sure.
« Reply #2 on: May 08, 2008, 04:32:34 AM »
Oil in the cylinder is usually either bad rings or bad valve seals. I'd do a compression test.
Offline pepatt
  • 174
« Reply #3 on: May 08, 2008, 05:59:52 AM »
Do you mean there's oil on the top (exterior of the plug), or on the business end?
If it's the top, you have a leaking valve cover gasket. If it's on the electrode you've got other issues, and you're probably seeing a lot of blue smoke. That's rings.
pepatt
Offline Carnage
  • 2453
« Reply #4 on: May 08, 2008, 10:18:48 AM »
Its on the exterior of the plug
Running very well though, good mileage and no smoke whatsoever
Offline aaron74
« Reply #5 on: May 08, 2008, 12:08:29 PM »
I don't know how conductive oil is but you might be losing some spark to ground.  I'd be more concerned about the wires getting oil on the insulation - quick way to wreck wires - but that is probably not happening here.  Alternatively, if you don't mind a little Exxon emulation, you could just leave it to slowly weep until you do your next valve lash adjustment.
Offline Carnage
  • 2453
« Reply #6 on: May 08, 2008, 07:12:32 PM »
cool, thanks for the info
