hi beams are gone????
  • 12 Replies
  • 3330 Views
Offline Eden1
  • 73
« on: May 09, 2008, 05:45:00 AM »
Does anybody have a idea what could go on these hi beams.I dont no when they went down,I do know they wernt there the other night.the hi beam indicater comes on and the lights go completly out???is there a fuse or something im lookin for..thanks again guys
Offline blknight87
  • 417
Re: hi beams are gone????
« Reply #1 on: May 09, 2008, 06:38:19 AM »
never heard of both high beams going out at the same time, but when your high beams go, it usually means that your high beam in the bulb has burnt out, what are u driving, in the newer cars, there is a relay in the engine compartment, in the big fuse block, it'll state 'high beams'   I would pull a bulb first... do u know how to see if a bulb is bad?
87 sammy-JX
U4WDA/IBZK
1.6 8V w/ MY-SIDE2-44mm SE carb
Thorley Header
Rebuilt trans, and t-case w/6.5-1's
SPOA 6"s w/ Rancho springs
275-85-15's buckshot mudders
Rino Line
RIP "BLKNIGHT" FOR YOU ARE MISSED
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #2 on: May 09, 2008, 06:44:15 AM »
Black hat?
XL-7 front coils
1.5" rear coil spacers
Offline Armour
  • 360
« Reply #3 on: May 09, 2008, 06:06:02 PM »
I would say if the indicator is coming on you may need new bulbs. Take a test light and check for power at the bulb
Offline rascott
  • 669
  • 15
« Reply #4 on: May 09, 2008, 08:30:13 PM »
perhaps relay went bad(wearing black hat).
unlikely both filaments went at the same time.
Offline RACER X
  • 383
  • zuki or die!
« Reply #5 on: May 10, 2008, 12:50:41 AM »
I had one hi beam on one side of the car and on the other side a low beam. Dealer had never seen any thing like it so after a hundred bucks.They changed out both the bulbs all was fine after that later on a mechanic friend says water in the electrical cause's strange prob like that (no more swimming for my kick)
98 kick
Offline 95 Tracker
  • 33
« Reply #6 on: May 10, 2008, 12:01:33 PM »
me too but its because of corrosion
Offline Eden1
  • 73
« Reply #7 on: May 10, 2008, 10:43:41 PM »
Its a 92 tracker.Whats a black hat?And where is the relay located on a 92?I can feel it where getting closer to a fix.its kinda ok about the high beams-i  went out and bot some light force off road lights,you can see thru trees with them puppies on.still need yhr high beams.
Offline rascott
  • 669
  • 15
« Reply #8 on: May 10, 2008, 11:35:43 PM »
ignore all this- i looked thru my manual(chilton's p.o.s.) and see no reference to relays.
you have checked fuses?
ignore the black hat.
Offline Eden1
  • 73
« Reply #9 on: May 11, 2008, 07:46:42 PM »
ok there is no power going to the hi beam????what next??
Offline kingzoo
  • 461
  • I LOVE MY JLX SIDEKICK
« Reply #10 on: May 11, 2008, 08:20:41 PM »
   Check a manual for the wiring diagram or follow the wire along it,s course if you can,t get to a manual.It could be anywhere from the fuse box,the switch,or a fault in the wiring in between.My ber is on the switch,but I am usualy full of shit.
KING ZOO!!
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #11 on: May 11, 2008, 09:11:10 PM »
Whats a black hat?
Obscure joke.  Never mind.  Not helpful.
XL-7 front coils
Offline Sidetracker
  • 30
« Reply #12 on: May 14, 2008, 05:15:43 PM »
If it's a Canadian vehicle then it could be the daylight running light module.  I had to replace two.  When mine broke the first time the wasn't any high beams and the second time the wasn't any headlights at all.
