RADIATOR FLOW
RADIATOR FLOW
Dazookster
61
RADIATOR FLOW
May 09, 2008, 03:25:41 PM »
I am putting an electric fan in my samurai and was wondering which hose was the inlet on the radiator top tube or bottom one?
Wahoo for Global Warming more time to go Wheeling
ROSS
1412
WHY TAKE A PICTURE WHEN YOU CAN DRIVE OVER IT
Re: RADIATOR FLOW
May 09, 2008, 05:33:32 PM »
water flows in the top and out the bottom. don't all flow that way??
87 SAMI 1600 FUEL INJ. , TORQUER CAM, 6.5 TO 1T-CASE, 5"SPRINGS SHACKLE REVERSE ,2 BODY LIFT, LOCK-RITES FRONT W/ HEAVY-DUTY AXLES & ARB'S REAR BFG 31 X10.50 X 16", EXO SKELLETON,
Amilla
1076
Toyota running gear was made for a samurai!
Re: RADIATOR FLOW
May 10, 2008, 12:11:39 PM »
do you have a flex-a-lite fan?
Amilla
JARYsidekick
47
Re: RADIATOR FLOW
Reply #3 on:
May 11, 2008, 11:06:52 AM »
I haven't seen any yet that doesn't flow from top to bottom.
Also, I would suggest using 2 small fans (about 9" or so) with independent relays so that if one dies the other still works.
Dazookster
61
Re: RADIATOR FLOW
Reply #4 on:
May 12, 2008, 07:41:20 AM »
Ya I have a flex a lite fan it worked great on the trail didn't over heat at all. I figured the inlet hose was the top but didn't know for sure .
